Can I use both type of valves?
Old Oct 12, 2005 | 03:23 PM
unix4linux's Avatar
Default Can I use both type of valves?
I have a gsr head and mating it with an ls block. The gsr head is complete skunk2. The only problem is that I was missing two skunk2 valves when I got the head because those two valves were needed for another app. I had some ferrea valve for the gsr head laying around. I added 14 skunk2 valves and two exhaust side ferrea valves to compensate for the missing skunk2 valves. Will I be ok with this? I have heard that as long as the valves are for the same application that I shouldn't have a problem. What do u guys think?
Old Oct 12, 2005 | 03:31 PM
DonF's Avatar
Default Re: Can I use both type of valves? (unix4linux)
Just cc the chambers with the valves installed, to make sure the compression ratio will be the same. Or buy the correct valves.
Old Oct 12, 2005 | 04:14 PM
unix4linux's Avatar
Default Re: Can I use both type of valves? (DonF)
DonF: What do u mean by CC the chamber? Thanks for your prompt reply as well :-)
Old Oct 12, 2005 | 04:45 PM
DonF's Avatar
Just something I heard about keeping combustion chamber volume the same, as well as cylinder volume and then working out the compression ratio.
Old Oct 13, 2005 | 01:26 AM
unix4linux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Just something I heard about keeping combustion chamber volume the same, as well as cylinder volume and then working out the compression ratio. </TD></TR></TABLE>
Ok but how is this done? Do I take the head to a machine shop or something?
Old Oct 13, 2005 | 12:02 PM
Phatch99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unix4linux &raquo;</TD></TR><TR><TD CLASS="quote">
Ok but how is this done? Do I take the head to a machine shop or something?</TD></TR></TABLE>
yes.
junkyard racer
Sep 7, 2008 04:41 PM
ONE*SICK*FERIO
May 6, 2008 09:07 PM
speedracer9k
Oct 13, 2003 06:32 AM
B18C1_CRX
May 15, 2003 06:32 AM
