need some help or good advice!!!
hey guys just wondering what u think of my current build and numbers that i made.
first off my build consists of :
Dart 85mm buttom with type r crank
corillo rods
endyn 12.5 roller wave piston-cometic head gasket
top end consist of
Pr3 head ported with full portflow valve train
Stage 3 crower cam which the head was degreed so piston to valve contact was not a problem,
jg intake manifold-
vibrant header 4-1 design
310 Rc injectors
tuned with hondata
my question to u is i made 205whp 151torque at 8200rpm my tuner messed my redline up but do think i should make more power at the top, and where do think i should redline at. Thanks Sam
corillo rods
top end consist of
jg intake manifold-
310 Rc injectors
tuned with hondata
With an 87.2mm crank it shpuld be making peak power much higher. What are you cams degreed at? What did you AFR map look like. What duty cycle were those 310 injectors at and what fuel pressure are you running?
4LugR
13
Feb 13, 2007 02:28 PM
