question on wich tranny i need?
Old Oct 12, 2005 | 12:23 PM
thugciti01's Avatar
Default question on wich tranny i need?
i have recently purchased a 92 civic hatch. the previous owners did a swap with a jdm d15b, it came with an automatic tranny so they swaped it in too. i'm going to put a 5 spd back in but not sure what tranny i need( like what year and make of car i could get it from) so any help on this would be greatly appreciated.
Old Oct 12, 2005 | 12:25 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: question on wich tranny i need? (thugciti01)
any SOHC trans will work. Do some research on an auto to manual conversion because the side trans mount will have to be replaced (welded in) as well. Also an auto ECU will give you a check engine light when used with a manual trans.
Old Oct 12, 2005 | 12:28 PM
JDM-EJ1's Avatar
Default Re: question on wich tranny i need? (HondaFanatic708)
The D series motor can work with any D series tranny. An s20 or an s40 will work fine.
Old Oct 12, 2005 | 12:34 PM
thugciti01's Avatar
thanks for the info, as for the car it was a 5 spd that they converted to auto but he left every thing in like (clutch master cylinder,pedals, lines, ecu, etc.) again thanks for the help
Old Oct 12, 2005 | 12:36 PM
00CivicGirl's Avatar
damn if they left everything in, your auto - manual swap wont be much at all
Old Oct 12, 2005 | 12:40 PM
JDM-EJ1's Avatar
Default Re: (00CivicGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">damn if they left everything in, your auto - manual swap wont be much at all</TD></TR></TABLE>
Definitely..
Here is a thread I made of a complete parts list for an auto to manual tranny swap.
https://honda-tech.com/zerothread?id=1316692
Old Oct 12, 2005 | 12:41 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thugciti01 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info, as for the car it was a 5 spd that they converted to auto but he left every thing in like (clutch master cylinder,pedals, lines, ecu, etc.) again thanks for the help</TD></TR></TABLE>
damn you're lucky.
try to find a tranny with the closest gear ratios as possible. With a d series, that's one of the best acceleration improvements you can make.
Old Oct 12, 2005 | 12:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">damn if they left everything in, your auto - manual swap wont be much at all</TD></TR></TABLE>Really just the side mount and everything else would be like a straight-forward trans swap.
Old Oct 12, 2005 | 01:12 PM
JDM-EJ1's Avatar
Default Re: (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">Really just the side mount and everything else would be like a straight-forward trans swap.</TD></TR></TABLE>
JDMSh!t.com sells an excellent mount to accomplish that.
kcassis
Jan 5, 2005 04:46 PM
JoeCDN
Sep 18, 2004 10:33 PM
AK77
Aug 24, 2004 07:10 PM
PhatboyNYC
Nov 6, 2002 07:47 PM
KevronsEG
30
Oct 17, 2002 01:26 PM
