Any ideas on how to tighten radiator fan blade to the motor?
Old Oct 12, 2005 | 11:39 AM
TheMacGuy's Avatar
Default Any ideas on how to tighten radiator fan blade to the motor?
Recently replaced the radiator fan and condenser fan motors on my '91 --- both were bad. I recall the condenser fan blade having a notched hole that slipped over the motor spindle. It's still fine.
The radiator fan blade just has a hole, not a notched hole, so tightening it so that it stays on the spindle has been a challenge. In fact, it worked well for about 2 months and has now come loose.
However, it isn't the that nut had that came loose. This isn't a situation where Loctitte would have helped --- I had the nut tight and with a locking washer as well.
What happened is that the fan blade slipped down onto the spindle some more, relieving pressure from the nut holding it on the other side.
10-2 of Helms only shows one washer used, between nut and fan blade. However, when assembling it that way, this gives the fan blade even less of a "footing" to sit well on the spindle (I had that washer on the backside of the fan blade because it acted as a perfect stopper on the spindle to keep the blade and the right depth.)
Anyway, none of that seems to matter if I can't tighten the nut --- the spindle will turn because holding onto the fan blade does nothing. I want a fan blade with a notched hole!
Old Oct 12, 2005 | 12:02 PM
TheMacGuy's Avatar
Default Re: Any ideas on how to tighten radiator fan blade to the motor? (TheMacGuy)
On second thought I might try and find a washer with a notched hole and J-B weld it to the fan, thereby creating my fan blade-with-notched-hole. What a pain in the ***.
Old Oct 12, 2005 | 03:50 PM
TheMacGuy's Avatar
Scratch that, none readily available. Gonna make something up with washers and a woodruff key; I'll cut one side off two washers and make the woodruff key fill in the circle, leaving me with in effect a washer that's notched on the inside.
Old Oct 12, 2005 | 04:32 PM
TheMacGuy's Avatar
OK kids, here's a visual of what I want:
Old Oct 12, 2005 | 04:38 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMacGuy &raquo;</TD></TR><TR><TD CLASS="quote">OK kids, here's a visual of what I want:
Take a look on your old fan motor, there should be one on it. If not, they can be had at your freindly local honda dealer.
Old Oct 12, 2005 | 05:24 PM
TheMacGuy's Avatar
Default Re: Any ideas on how to tighten radiator fan blade to the motor? (Chiovnidca)
Edit: I don't recall seeing such a thing on the OEM motor. As it is I kept a normal looking washer (shown between nut and fan in the Helms) and a thicker, smaller (outer) diameter, bigger (inner) diameter washer that doesn't seem to do anything.)
Real hardware stores (Home Depot & Lowes didn't have one) are what I may try next.
Hmm, I'll try Honda too --- but that begs the question: Why would such a thing be sold separately? I'd still need a way to attach (weld or glue) such a washer to the fan blade to prevent the fan blade from spinning on the motor spindle ...
Modified by TheMacGuy at 10:48 PM 10/12/2005
SGT_Manny
11
Jun 15, 2010 04:56 PM
Obama
Mar 2, 2010 05:33 AM
89 civic si
Sep 28, 2006 07:14 AM
BHNTech
Apr 29, 2006 07:39 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
