Colored carbon fiber?
Old Oct 12, 2005 | 11:34 AM
2.2 teg's Avatar
Default Colored carbon fiber?
anyone know where i can find some colored carbon fiber hoods?
Old Oct 12, 2005 | 11:40 AM
rhd's Avatar
rhd
APC possibly? they've used it in hoods that i've seen....might want to contact them and see if they'd name a supplier....doubtful, but worth a shot
Old Oct 12, 2005 | 02:13 PM
99blackcivicSi's Avatar
Default Re: (rhd)
i have seen a blue/carbon, fiber images they make great stuff, looked good to, they still might do that, check em out
Old Oct 12, 2005 | 03:50 PM
Dr Pooface's Avatar
Default Re: (99blackcivicSi)
Why is this post here? This forum is for fabrication discussion.
Old Oct 12, 2005 | 06:52 PM
k24em2's Avatar
Default Re: (Dr Pooface)
The "colored" part is actually kevlar.
Old Nov 20, 2005 | 12:28 PM
carbonall's Avatar
* B A N N E D *
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">The "colored" part is actually kevlar.</TD></TR></TABLE>
or if you wanted silver it is fiberglass that has been aluminized
Old Nov 20, 2005 | 04:30 PM
eHoward's Avatar
We use polyester. It's easier to work with then kevlar.
Old Nov 21, 2005 | 12:38 AM
k24em2's Avatar
Default Re: (eHoward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eHoward &raquo;</TD></TR><TR><TD CLASS="quote">We use polyester. It's easier to work with then kevlar.</TD></TR></TABLE>
Haven't seen that. I usually get my cloth (in very limited amounts mind you) from fiberglast.com.
Old Nov 21, 2005 | 01:39 AM
L-CON1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">The "colored" part is actually kevlar.</TD></TR></TABLE>no its not.
Old Nov 21, 2005 | 07:43 AM
carbonall's Avatar
* B A N N E D *
Default Re: (L-CON1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-CON1 &raquo;</TD></TR><TR><TD CLASS="quote">no its not.</TD></TR></TABLE>
Then what is it? I have tried to dye carbon and everyone I know that has tried to dye carbon, it does not work, carbon fiber from my testing and many others does not take dye. That is why they use kevlar in it, because it does take the dye. Or they will use fiberglass and dye that
Old Nov 21, 2005 | 09:18 AM
k24em2's Avatar
From where I get mine, it is dyed kevlar.
http://www.fiberglast.com
Old Nov 21, 2005 | 09:21 AM
carbonall's Avatar
* B A N N E D *
go to http://www.uscomposites.com so much cheaper then fibreglast!
Old Nov 21, 2005 | 11:13 PM
L-CON1's Avatar
Default Re: (carbonall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonall &raquo;</TD></TR><TR><TD CLASS="quote">
Then what is it? I have tried to dye carbon and everyone I know that has tried to dye carbon, it does not work, carbon fiber from my testing and many others does not take dye. That is why they use kevlar in it, because it does take the dye. Or they will use fiberglass and dye that</TD></TR></TABLE>FIBERGLASS!
Old Nov 22, 2005 | 04:19 AM
JDubya's Avatar
If its SOLID blue than it's probably colored glass. But if its black and colored then it's most likely carbon/kevlar or carbon/polyester.
Old Nov 22, 2005 | 06:15 AM
carbonall's Avatar
* B A N N E D *
Default Re: (JCDubya)
I have a couple solid colors such as silver, blue, red, and also gold and it is fiberglass. All of it aluminized. I have not seen fiebrglass and carbon mixed to make colors.
chelude
Oct 20, 2007 11:41 PM
chairwitharmrests
Welding / Fabrication
Sep 4, 2007 11:48 AM
buda18
Oct 10, 2006 11:41 AM
Shingo
May 13, 2006 05:58 PM
hi-Powered
Nov 12, 2005 10:55 AM
