Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sparco Bucket Seat, which slider/bracket?
Old Oct 12, 2005 | 09:50 AM
GR_DC2's Avatar
Default Sparco Bucket Seat, which slider/bracket?
I have a small problem. I have a sparco Corsa bucket seat, however i need to find out what low position seat bracket/sliders will fit on it. I am currently running Sparco steel sidemounts, spaco sliders, and the diamond cut sparco base. The problem is that my seat has a lot of side to side play because of the sliders--which has almost not passed me through tech at track days. Sparco says that the side mounts weren't meant to be attached to the sliders (sliders were meant for bottom mount seats), that the side mounts were meant to bolt directly down to the seat base and have no forward/backward adjustment. This is a problem because i am only about 5'6" and w/ the seat mounted directly to the base as far as it can go forward, i can hardly reach the peddles. Short story--i need adjustment.
I talked to Mark at SP Engineering and he said he's pretty sure Bride Bracket/slider combo's won't fit on my sparco seat. Any of you have experience with this? I want people that are certain about what will fit, not bunch of weak speculation. If you or you know anybody w/ a sparco bucket running some sort of slider mechanism, what are they using? thanks.
89hatcher
May 29, 2007 08:02 AM
GoCarInteg
Oct 19, 2005 06:43 PM
GR_DC2
Oct 12, 2005 06:14 PM
Smitdog
May 17, 2003 07:34 PM
ShowSpeed
Oct 10, 2002 07:32 PM
