Sparco bucket w/ what bracket/slider?
I have a small problem. I have a sparco Corsa bucket seat, however i need to find out what low position seat bracket/sliders will fit on it. I am currently running Sparco steel sidemounts, spaco sliders, and the diamond cut sparco base. The problem is that my seat has a lot of side to side play because of the sliders--which has almost not passed me through tech at track days. Sparco says that the side mounts weren't meant to be attached to the sliders (sliders were meant for bottom mount seats), that the side mounts were meant to bolt directly down to the seat base and have no forward/backward adjustment. This is a problem because i am only about 5'6" and w/ the seat mounted directly to the base as far as it can go forward, i can hardly reach the peddles. Short story--i need adjustment.
I talked to Mark at SP Engineering and he said he's pretty sure Bride Bracket/slider combo's won't fit on my sparco seat. Any of you have experience with this? I want people that are certain about what will fit, not bunch of weak speculation. If you or you know anybody w/ a sparco bucket running some sort of slider mechanism, what are they using? thanks.
You can always get them custom fabricated
Dont do that though, unless you are for sure they can do it right. If it is a bucket seat than why would it slide? Dont they sit in one position?
MemoryFab has a set of rails/brackets that will fit it and they're almost rediculously low. They're also comparitively light when weighed against many of the other rail/bracket combinations on the market.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9GUY-637 »</TD></TR><TR><TD CLASS="quote">You can always get them custom fabricated
Dont do that though, unless you are for sure they can do it right. If it is a bucket seat than why would it slide? Dont they sit in one position? </TD></TR></TABLE>
yes, it's a fixed back (bucket set), but i still need forward/backward adjustability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">MemoryFab has a set of rails/brackets that will fit it and they're almost rediculously low. They're also comparitively light when weighed against many of the other rail/bracket combinations on the market.</TD></TR></TABLE>
o yeah i forgot about memoryfab. i guess i'll email them tonight to see if they know if their brackets will fit on my seat. do you have personal experience w/ using a memoryfab bracket/slider w/ a sparo seat?
Dont do that though, unless you are for sure they can do it right. If it is a bucket seat than why would it slide? Dont they sit in one position? </TD></TR></TABLE>yes, it's a fixed back (bucket set), but i still need forward/backward adjustability.
GR_DC2
Oct 12, 2005 09:50 AM
Madracer1
Dec 20, 2002 04:36 AM
ShowSpeed
Oct 10, 2002 07:32 PM
