95 Accord broken into, locks damaged
About a month ago my 95 Accord was broken into. I have the factory remote entry and alarm so when the alarm went off the thieves ran. But my passanger side lock is damaged, the keyhole is pushed in and I cannot use a key on that lock. I have attached a pic of the lock
Also, recently (a month after the car was broken into) my power locks no longer work. I have to manually lock the drivers side with the key and the passanger side by pushing the lock on the inside. I have taken the door skin off to make sure the power lock plugs are still attached and they are.
Thanks for any help!!
Remove your door panel, have your window up, and be careful when removing the panel... because there's a wire connected from inside the door handle to the manual handle inside the car... ....remove it carefully... and try to put things back in order... ...if needed.. unscrew your door handle... fix the key hole and put everything back....
I know this sounds a little complicated... but it shouldn't be so hard!
Tonyl507
Audio / Security / Video
May 15, 2011 07:07 AM
khronicboy420
Jan 3, 2009 12:37 PM
neilscully
Jul 26, 2004 08:26 PM
