90 EF hatch. EG seats...Already searched....
....and all I could come up with were answers like u need to modify this or swap that. that was for crx's though and from what I have leanred. the rails and the floor of the car is different on hatchs and crx's.
I need a definitive answer on how to fit these nice 95 eg seats that I just got for 20 bucks. If the rails need to be modified. please tell me exaclty how and if thinngs need to be switch. please tell me what to switch and from which car to which seat.
thanks
pics can be sent to soulstance@aol.com if anyone has anything that would help.
right now I am riding on seats w only 2 bolts holding me in casue thats how I got the car about a week ago when I bought it ...
thanks
Best bet is to go to a machine shop and ask them to make rails for you that will work.
Or you can take the rails off of your EF seats and weld them to the EG seats.
You can do it but it takes a lot of fabrication.......I used to have a set of EG seats in mine....when the side upolstry wore through I ploped in a set of prelude seats.
If you do it make sure you do it safely....don't want to hear of you dieing from a minor accident becasue the seats tore loose.
HAHAHAHA everyone told me i could not be done so i said expletive you and did it nowi have very confortable seats in my 91 dx hatch i got the seats out of a 93 sedan (a friends of mine) used the stock eg seat rails i had to cut a LITTLE out of them but other than that they fit good, the rail slide even, back rest moves up and down like it is suppost to. and they said i need to go and make custom brakets(sp)
f that i win if you want to put them in you will find a way
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efgrey87 »</TD></TR><TR><TD CLASS="quote">HAHAHAHA everyone told me i could not be done so i said expletive you and did it nowi have very confortable seats in my 91 dx hatch i got the seats out of a 93 sedan (a friends of mine) used the stock eg seat rails i had to cut a LITTLE out of them but other than that they fit good, the rail slide even, back rest moves up and down like it is suppost to. and they said i need to go and make custom brakets(sp)
good luck</TD></TR></TABLE>
I didn't find the EG seats to be comfortible...but I did find a matching set for real cheap thats why I used them. I would take photos of what I did but those seats are long gone.
Its hard to explain too...I used a combination of square and rectangular tubing and some angle iron, some welds and grade 8 bolts...yes I could have done it lighter..but I wanted to be sure in an accident the seat stayed secure.
good luck</TD></TR></TABLE>I didn't find the EG seats to be comfortible...but I did find a matching set for real cheap thats why I used them. I would take photos of what I did but those seats are long gone.
i did no welding and and i used that stock bolt that were used for the ef seats. all i did was cut a 1/2 in. piece out of both brackets and it fit fine the seat belt buckle work as well,,, i was saying that they are more confortable that the stock ones that i had in my car b/c they both had major rips which sucks so i got these,,, they are in my car right now but i do not have a camera to take any pics
when i put my 2001 s2000 black leathers in my crx this was my procedure:
1) take it to my welder.
2) tell him i want these seats in this car, perfectly level with working slider and recline.
3) pay 250$
4) drive car away
he welded the seats to the factory crx si rails, then painted it flat black. people who dont know hondas often think they came with the car.
if you dont do it with four bolts holding the seat down your taking a car thats already a death trap, and now your head will be flying through the windsheild even in a low speed crash.
ive seen people use sheet metal and even pieces of wood to get their seats in, its all a matter of how ghetto fabulous you want it to be....
3) pay 250$
4) drive car away
nice s2k seat
all four bolt are on both seats they fit with no movement sliders work and recline works expletive people who use wood and sheet metal * that is a death wish*
Thanks thatss a good Idea to just take it to a realiable welder.
A local guy says that he had done it by making a bracket for the bolts that dont line up out of angle iron. he bolted it to the factory hole and then drilled a new hole in the angle iron and bolted the seat to the angle iron. sounds like that is pretty secure.
