another b20 in the making
hey peeps rite just wanna know some bits on the b20 rite what is the best way to go wit the block, there is the b20b,b20z the b20b is outt the 97-98crv and the b20z outta the 98-01 so what do u think i should get the b20z has more power than the b20b on the crv but ive heard diff storys bout both blocks im puttin a b16a2 head on the block if that helps im gonna b buildin the engine from bottom to top everythink done nuttin miss'd thanks for ya help!!!!!
Modified by civboy at 7:03 AM 10/12/2005
I heard the b20z is the stronger motor with more horsepower and higher compression. But good luck finding the motor, I searched lots of places and could not find the motor. I have a JDM B20b in my EG and I love it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If your going to build it get whichever is cheaper and sleeve it. </TD></TR></TABLE>
If your not gonna build the motor i would run the b20b.. The b20z is a awesome block i had a b20z with a vtec head and it ripped. Right when i put some cams in all of my intake valves bent cause they hit the pistons. If you do a b20z don't change the cams in less you get it tuned. my friend had a b20b with skunk2 stage2s and never had a problem.
thanks for ya info i found a b20z 10,000miles on the engine 500quid ya im buildin the block up wit vtec and b16a2 head skunk 2 stage 2 cams will b goin in lol etc etc it will b done proper hopfuly i'll run it on the strip som time nxt yr i'll get a vid done and put it up ^_^
JDMroyEG5turbo
Mar 13, 2006 01:18 PM
