need ur oppinion on gsr
Guest
Posts: n/a
i need ur oppinion mang.. im running bone stock at da moment.. just da basic I,H,E. i have a sk2 manifold. it doesnt run all that great and lost alot of torque also.. it also doesnt run all that gr8 with da srock ecu. should i go back to stock manifold for my torque and butterflies or stick wid da sk2 manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsrvtek19 »</TD></TR><TR><TD CLASS="quote">I need ur oppinion man.. I'm running bone stock at the moment.. just the basic I,H,E. i have a sk2 manifold. and it doesnt run all that great and lost alot of torque also..it [omit]also[/omit] doesnt run all that great with the stock ecu. should i go back to stock manifold for my torque and butterflies or stick with the sk2 manifold. </TD></TR></TABLE>
Fixed it to understandle text
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsrvtek19 »</TD></TR><TR><TD CLASS="quote">what arer you a teachers pet ? </TD></TR></TABLE>
Stfu GTFO jackass. Go jump off a cliff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin »</TD></TR><TR><TD CLASS="quote">
How about you GTFO unless you can help the guy?
Right on, aside from being mean, yes replace your stock unit and try tuning it, the Aftermarket IM you have draws in more air and without having the right set-up can kill your low end power, with what you listed you should have decent top end power.
Try going back to the stock IM unit and see how the car responds. If its still the same, run through each part until you find what is killing your low end power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRintegra_Bob »</TD></TR><TR><TD CLASS="quote">i can't tell if your serious or not... if you are i know where you can get some great hooked on phonics tapes for cheap</TD></TR></TABLE>
SHH DON'T Do that.
Just help him out.
SHH DON'T Do that.
Just help him out.
