Correct valve spring install height?
same as stock, refer to haynes or chiltons manual, it is very hard to measure on our heads as it is soo tight. I have yet to shim any of mine, you can usually get away with measuring open and closed seat pressure and if they are fine dont worry too much unless you have a crazy lift camshaft.
Balor_Gr
May 4, 2018 12:03 PM
