Why is it rubbing?!
Hey guys I had an accident a few days ago. I bent my front passenger LCA and I found out today that I bent my spindle. I replaced everything but now the bolt for the lower ball joint is scraping into my rotor. I can not figure it out. Please help me HT I've always counted on you guys for answers!
As I lower the car, the LCA/castle nut closes in on the plate to the rotor. There's a hole in the dust shield now since it closed in on each other
did you check to see if the knucle was bent. exactly how did you get hit? if anything on the front suspension is bent will throw off the alignment of parts in there.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chucko200 »</TD></TR><TR><TD CLASS="quote">did you check to see if the knucle was bent. exactly how did you get hit? if anything on the front suspension is bent will throw off the alignment of parts in there.</TD></TR></TABLE>I was thinking the knuckle as well, that doesn't look good, def. don't drive like that. But that was replaced, so it could be up top. I had suspension issues (bent lower arm) bought a LCA from a bone yard they assured me wasn't bent but it was, so I replaced with new parts. I'm thinking if its not the LCA, knuckle try looking at the UCA or damper fork. Really all thats left beyond those that could throw off suspension geometry that bad is a bent frame or possible a bent front subframe.. Good luck.
ummmm..thats funny b/c i got into an accident also with my 99 coupe...whenever im driving ....i hear a rubbing/scrapin noise on my right side...oh by the way i got hit on the front by the right fender ...do you guys think i have the same problem>>??..thanx in advance
yea me 2 thanx...yo can i ask you a ? my boy said he would charge me only $200 to get the damages repaired....for example my right fender and bumper..all i need to do is pay for the paint and he said he would spray and put on for me.... do u think 200 is to good to be true
civicrr
17
Jul 7, 2002 09:04 PM
