does any resistor box work for dpfi to mpfi?
Old Oct 11, 2005 | 01:54 PM
ZCcivicBOI's Avatar
Default does any resistor box work for dpfi to mpfi?
i got a 88 hatchback im gunna do mpfi swap and i got a resister box from obd1 car does it matter or not
Old Oct 11, 2005 | 02:18 PM
Mach69's Avatar
Default Re: does any resistor box work for dpfi to mpfi? (ZCcivicboy)
You have a resistor box from an obd-1 car? I find that odd, because I do not know of any obd-1 car that had a resistor box. Obd-1+ injectors are high voltage injectors, meaning they work without a resistor box because the resistor box lowers the voltage.
Did you even get it out of a honda?
If you have a resistor box with a 5 wire plug, it should work.
Old Oct 11, 2005 | 02:27 PM
ZCcivicBOI's Avatar
its out of an accord i think but the plugg is 5 wire
Old Oct 11, 2005 | 04:54 PM
zbaber's Avatar
Default Re: (ZCcivicboy)
i have found the resistor box out of a 86-87 integra to work very easily..
Homotor
Dec 14, 2007 12:29 PM
mouch33
Dec 21, 2005 05:44 PM
Lissav
Nov 12, 2005 11:52 PM
vtekthis
Dec 20, 2003 01:34 PM
