how to paint my valve cover shiny
Old Oct 11, 2005 | 01:49 PM
EG93si's Avatar
Default how to paint my valve cover shiny
i saw that pic of that valve cover witht the rising sun flag on it, how would i go about painting mine to close of that quality counting the biggest resources i have are walmart and autozone, a couple of step by steps would be nice
EG93si's Avatar
valve cover is off/cleaned/degreased
Old Oct 11, 2005 | 02:04 PM
JoKarma's Avatar
Default Re: (EG93si)
Stickies at the top of the page have you covered.
You might try searching too.
Autozone and walmart should have everything you need.
Old Oct 11, 2005 | 02:27 PM
EG93si's Avatar
i read those and search, i just want to know how to make its nice and smooth, i want it as close to this as possiable https://honda-tech.com/zerothread?id=1362165,
im guessing just get a scotch brite pad and go to town, paint it white a couple coats, then tape it all off and do the red over top?
any clears or primers?
Old Oct 11, 2005 | 02:31 PM
JoKarma's Avatar
I dont paint valve covers but I'd say you have the right idea.
As far as clear or primers.. Id start with a primer and probaly do a heavy clear.
Old Oct 11, 2005 | 02:35 PM
royale10's Avatar
a clear coat will make the paint more durable and shinier which seems to be what you are looking for
Old Oct 11, 2005 | 02:52 PM
EG93si's Avatar
but is it ok since its going to be hot and all?, second how do i go about the oem rinkle finish will it just come off with just regular sanding? like scotch brite?
Old Oct 11, 2005 | 03:16 PM
JoKarma's Avatar
well sanding will take care of it.. you dont need it to be too smooth. rougher surface will give the paint a better platform.
BiffStroganoffsky's Avatar
sanding will work but you would do better with a can of stripper from home depot or lowes. less elbow grease and less possible damage to the cover.
Old Oct 11, 2005 | 07:09 PM
built562's Avatar
Default Re: (BiffStroganoffsky)
best way is to get paint stripper and strip the wrinkle finish.
then prep the surface for primer by scuffing the valve cover and then cleaning it again and taping all stuff off that you dont want painted. then make sure the valve cover is warm, like sit it in the sun or a heat lamp. then do your high heat primer.
then do your base coat of white, like 3 coats will do.
Make sure you let the paint completly dry before you tape it up to paint the Red.
then take the tape off and do like 3 clear coats.
you might get some orange peel so you might want to color sand
good luck
huviduc
Oct 3, 2006 04:07 PM
B18C-YA!
Jul 30, 2006 08:46 AM
ih8danoles
Oct 27, 2002 01:22 PM
Lookincrazy
Jul 6, 2002 12:52 AM
TheHater
Jun 27, 2002 09:14 PM
