Stock Suspension Questions.
Old Oct 11, 2005 | 12:51 PM
iixerOii's Avatar
Default Stock Suspension Questions.
I am currently running on stock shocks and springs that have about 151XXX miles on them. The car sits noticeably lower than stock so if they (shocks) aren't blown yet, they are getting there. My daily ride feels like absolute crap. Everytime I hit a bit of a hole the whole car shakes and feels like it's coming apart. My question is if I buy new OEM shocks but keep my old springs will I get a more comfortable ride? I'm not looking to lower my car cause I don't use it for auto X or push the handling limits anyway. Also I don't want to get into the whole getting camber kits, rolling fenders or anything like that. Another thing is I live in Philly PA where we have some of the worst rodes. My header is already dented and I haven't even lowered my car.
CLIFFNOTES: If I buy OEM shocks and reuse my old springs will my ride be more comfortable.
Old Oct 11, 2005 | 12:56 PM
purplegsr's Avatar
Default Re: Stock Suspension Questions. (iixerOii)
yes, replacing the OEM shocks should make a world of difference. Springs, especially OEM ones, are not designed to be a replacement/maintenance item, so they should respond very well to the new shocks. However, don't expect a stock ride, because after 150,000, your bushings, motor mounts, etc are also worn, so they end up transferring bumps and vibrations more than a brand new car.
Old Oct 11, 2005 | 01:12 PM
FULLY_BUILT_NA's Avatar
dude just lower you car for looks. you dont need camber kits. since you getting shocks might as well go tokiko or kyb gr-2 they are oem replacement but cheaper
Old Oct 11, 2005 | 01:16 PM
BlackLudeSi's Avatar
Default Re: (FULLY_BUILT_NA)
Didn't he say his car was sitting lower than other stock Tegs? If so then it is a spring issue to, Your springs deterimine your ride hight and the shocks control the compresion and rebound of the spring.
Old Oct 11, 2005 | 01:25 PM
1bad-eg's Avatar
Default Re: (BlackLudeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLudeSi &raquo;</TD></TR><TR><TD CLASS="quote">Didn't he say his car was sitting lower than other stock Tegs? If so then it is a spring issue to, Your springs deterimine your ride hight and the shocks control the compresion and rebound of the spring.</TD></TR></TABLE>
Old Oct 11, 2005 | 01:26 PM
redDAinteg's Avatar
koni yellow spend the extra, you wont regret it.
IROCKCIVICS
Honda Civic (2001 - 2005)
Sep 9, 2007 05:15 PM
20ls01
Suspension & Brakes
May 11, 2007 04:57 PM
idriveadelsol7
Suspension & Brakes
11
May 6, 2005 07:44 PM
ShAAdiiiNG
Dec 28, 2002 10:23 AM
