Code-9, N0. 1 cyliner Position, also have a miss. Pics of everything.
Hey guys whats up,
I have a 90 integra rs
B18A1, obd0
Well, My ecu is throwing a code 9
Code 9 - No. 1 cylinder Position.
I also have a miss, I believe in cylinder 3.
I have replaced the plugs and wires,
I was told code 9 was the dizzy,
So I took off the cap, the rotor looks fine,
do I need to take off the entire dizzy to check for problems,
All Help is Thanked.
Pics,
Thanks, I really would like some help and not 3000 people look at it and not even bump, As I have helped others on this board.
Thank you. TIA/
B18A1, obd0
Pics,
Thank you. TIA/
Borrow a friends dist and try it, or get a used one on ebay. There arent many ways to look at it and see if it works.
You reset your computer and how soon/what does it take to make the Code come back?
Sounds like the no.1 cylinder sensor is bad or going bad. Your misfire could also be related to the sensor problem. Really the only way to fix the problem is by replacing the distributor.
try this place for a distributor...
http://www.andale.com/stores/s...rking
NOOOOOOoooo!!!!!
Distibutor king sux, get a used OEM... maybe a new cap/rotor/igniter if it needs it.
I'll post everything about in a min,
Should I take the entire dizzy off to check it out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DA9IntegraRS »</TD></TR><TR><TD CLASS="quote">
Should I take the entire dizzy off to check it out?</TD></TR></TABLE>
Just replace it.
Just replace it.
FalkenSiR
Aug 1, 2005 10:36 AM
rukawa1one
Feb 15, 2005 05:53 PM
