Suspension & Brakes Theory, alignment, spring rates....
Omnipower front camber kit? No thank you...........
Old Oct 11, 2005 | 10:31 AM
WildPig's Avatar
Default Omnipower front camber kit? No thank you...........
I've had this omnipower front camber kit on my car for less than a year, probably about 9 months. Only autocrossed on these about 5-6 times, not really heavy racing or anything and look what happened over time:
This problem obviously comes from the metal/bushing combo being PRESSED into the red metal end peices, and not WELDED on like the factory ones are. This kit made some really ****** annoying noise ever since the day it was installed (correctly mind you) and I could never figure out where it was coming from. A month ago I took off my wheels to clean them and found this...... pretty crappy surprise.
I installed some V2 skunk2 front camber UCAs for now cuz they were the quickest ones I could get, but I have a feeling the same thing is going to happen to those too (they have the exact same serial number stamped into the arm metal).
BTW I've had omnipower sport coilovers, rear camber kit, and rear LCAs and they have all been fine, the bushings look a little worn on the rear LCAs but that's it.
What camber kit do you guys use and any other thoughts on this?
Old Oct 11, 2005 | 10:47 AM
di rang's Avatar
Default Re: Omnipower front camber kit? No thank you........... (WildPig)
how many miles on them?
Old Oct 11, 2005 | 10:50 AM
WildPig's Avatar
Default Re: Omnipower front camber kit? No thank you........... (di rang)
I'd say no more than 14-15k miles. They didn't last nearly as long as I thought they would.
Old Oct 11, 2005 | 10:57 AM
ek9vboi2's Avatar
wow, thats bad. looks like my buddy's skunk2's. the bushing only ripped out, not the whole metal part. but then again, the design was the old version.
as for me, eBay **** holding it down!!!
Old Oct 11, 2005 | 11:03 AM
WildPig's Avatar
Default Re: Omnipower front camber kit? No thank you........... (ek9vboi2)
****, I'm totally worried about my new v2 skunk2 ones. They are the exact same shitty design as these, why can't these companies take the time to just spot weld around the pressed-in metal peice? Doesn't make sense to me......
And I'll be pretty pissed if your ebay ones hold up for longer than these ones....
Old Oct 11, 2005 | 11:04 AM
Honda318dx's Avatar
Did you preload the suspension before you tightened the bolts?
Old Oct 11, 2005 | 11:12 AM
Tyson's Avatar
this is the second time ive seen this reported....
Old Oct 11, 2005 | 11:16 AM
ek9vboi2's Avatar
Default Re: Omnipower front camber kit? No thank you........... (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">Did you preload the suspension before you tightened the bolts?</TD></TR></TABLE>
I dont think preload has anything to do with the camber kit. Garbage is garbage, no way of changing that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">****, I'm totally worried about my new v2 skunk2 ones. They are the exact same shitty design as these, why can't these companies take the time to just spot weld around the pressed-in metal peice? Doesn't make sense to me......
And I'll be pretty pissed if your ebay ones hold up for longer than these ones.... </TD></TR></TABLE>
Why dont u get the bushing things welded to the arms? All my friend did was switch out the skunk2 bushing w/ stock ones off his car. As for me, mine came ready to bolt on. You know what I would suggest to people? get oem bushings and install it on ur aftermarket arms.
i dont need to, mine hold fine and best of all no camber wear!
Old Oct 11, 2005 | 11:37 AM
Honda318dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">
I dont think preload has anything to do with the camber kit. Garbage is garbage, no way of changing that.) </TD></TR></TABLE>
Yes, it does a little. If you tighten the bolt while the suspension is unloaded at full drop when you lower the suspension, the bushing will want to twist inside the arm and cause the press in to fail.. Granted, it shouldn't have done this...
Old Oct 11, 2005 | 12:17 PM
Andrew240z's Avatar
We have been running the Skunk's on our integras for the past two seasons with no problems (these things see a lot of racing) We do check the ball joints and replace them if necessary....
Old Oct 11, 2005 | 12:24 PM
Tyson's Avatar
Default Re: Omnipower front camber kit? No thank you........... (Andrew240z)
this specific problems seems to be particular to the EK arms because the bushings are mounted horizontally directly to the chassis, as opposed to an extra bracket that points the studs up. the EK design relies on the bushing being press fit into the arm, which requires a good control of tolerance to maintain fitment, which obviously failed here.
Old Oct 11, 2005 | 12:31 PM
ek9vboi2's Avatar
Default Re: Omnipower front camber kit? No thank you........... (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">this specific problems seems to be particular to the EK arms because the bushings are mounted horizontally directly to the chassis, as opposed to an extra bracket that points the studs up. the EK design relies on the bushing being press fit into the arm, which requires a good control of tolerance to maintain fitment, which obviously failed here.</TD></TR></TABLE>
very true.
Old Oct 11, 2005 | 12:38 PM
WildPig's Avatar
Yes, it does a little. If you tighten the bolt while the suspension is unloaded at full drop when you lower the suspension, the bushing will want to twist inside the arm and cause the press in to fail.. Granted, it shouldn't have done this...</TD></TR></TABLE>
Hmmm, that may have been one of the problems, although I did follow omnipowers instructions word for word and preloaded the coilovers but not the UCAs.
I'll look into that for my skunk2 ones right now.........and that's good news that the skunk2's have held up for a lot of people, but ever since I bought some strut bars from them that came with no hardware at all I've been a bit skeptical of the quality of skunk2's parts.
Hopefully they redeem themselves though.........
Old Oct 11, 2005 | 12:49 PM
WildPig's Avatar
Ok now I'm pissed..............
The annoying noise that I was speaking of in an earlier post did not go away, it started again after about 20 miles or so of driving. It's a knocking/squeaking/popping noise, it's kinda hard to describe........
wtf could it be? I thought before it was the arm coming off the bushing hitting the chassis but obviously it's something else. And when the car is up on stands I can't produce enough force to make the noise, it only happens when driving on a slightly bumpy road. Seems it only happens when the car is going up and down.......
Got any suggestions anyone?
Old Oct 11, 2005 | 02:16 PM
ek9vboi2's Avatar
maybe its the control arm hitting the top of the shock tower area???
my friend's skunk2 in his ek always hits it and puts indentures, now he has lil holes. lol
Old Oct 11, 2005 | 03:30 PM
sockvtec's Avatar
hmmmmm....i jus ordered my omni kit a couple of days ago
so what am i gonna need to do to keep this from happening??? just use my factory bushings?
Old Oct 11, 2005 | 04:03 PM
WildPig's Avatar
Default Re: Omnipower front camber kit? No thank you........... (sockvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">hmmmmm....i jus ordered my omni kit a couple of days ago
so what am i gonna need to do to keep this from happening??? just use my factory bushings?</TD></TR></TABLE>
I would say just take the camber kit to someone or a place that welds and have them weld a couple spots around the metal pieces near the bushings. And install them correctly by preloading the suspension before fully tightening them down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">maybe its the control arm hitting the top of the shock tower area???
my friend's skunk2 in his ek always hits it and puts indentures, now he has lil holes. lol</TD></TR></TABLE>
I was thinking about that but why would it do it ONLY on the passenger side? idk doesnt make sense to me, but I'll take a look anyway.....
Anyone have any other ideas?
Old Oct 11, 2005 | 04:14 PM
laezpnai's Avatar
hmm better check mine
Old Oct 11, 2005 | 10:38 PM
quisp's Avatar
was the A arm bushings tightened _after_ the suspension is set on the ground?
Old Oct 12, 2005 | 04:29 AM
Honda318dx's Avatar
Default Re: Omnipower front camber kit? No thank you........... (quisp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quisp &raquo;</TD></TR><TR><TD CLASS="quote">was the A arm bushings tightened _after_ the suspension is set on the ground?
Thats what my "preload" comment was implying. Its easier to get a jack under the control arm and compress it, that way you can still get your arms in there. Jack it up until the car corner slightly lifts from the jackstands..
Old Oct 12, 2005 | 04:31 AM
quisp's Avatar
yah but you know how lot of ppl love to bash on omni coilovers and preload so it wasn't clear if you were kidding or serious. :-) i'm pretty sure majority of EK installs people neglect to set the suspension before tightening.
Old Oct 12, 2005 | 04:36 AM
quisp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">this is the second time ive seen this reported....
do you guys know how many thousands of set the factory has produced these arms? the failure rate is pretty low.
Old Oct 12, 2005 | 08:10 AM
Marauder's Avatar
do you guys know how many thousands of set the factory has produced these arms? the failure rate is pretty low. </TD></TR></TABLE>
Nope, but how many other brands do we see having the same problem?
Old Oct 12, 2005 | 12:44 PM
WildPig's Avatar
Default Re: Omnipower front camber kit? No thank you........... (Marauder)
Yeah I know, a day before I found out that mine were this bad, I saw someone else on here who had the same problem. So I thought, man I should check mine out......... and this is what I found.
I'm pretty sure that skunk2 and omnipower get their "arm" assembly from the same exact company because they look the same and have the same code stamped into each of the arms.........not good.
Old Oct 12, 2005 | 01:27 PM
Real_E-AT's Avatar
Omni = Overhyped JUNK
