Help...major nitrous damage!
Old Oct 11, 2005 | 09:35 AM
ken00si's Avatar
Default Help...major nitrous damage!
My buddy was racing his 99 si a couple weeks ago with a 75 shot of nitrous from a Zex wet kit. His motor is all stock, he has all the basic bolt-ons, and he had colder spark plugs and retarded the ignition by 2 degrees as was recommended. On his 4th run something happened and his car started smoking and the engine was knocking like crazy! When he got the car home he pulled out the spark plugs and found that #2 was fried. He hasn't pulled off the head yet but he thinks that the #2 cylinder has some major damage to it. Fortunately his car is still under an extended warranty, but he's afraid to take it in. What do you guys think he should do? If he removes the nitrous kit and brings the car in will they be able to tell?
Old Oct 11, 2005 | 09:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Help...major nitrous damage! (ken00si)
I am pretty sure the dealership will deny that one. Sounds like you spun a bearing at the very very least.
Old Oct 11, 2005 | 09:40 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si &raquo;</TD></TR><TR><TD CLASS="quote"> If he removes the nitrous kit and brings the car in will they be able to tell? </TD></TR></TABLE>
Yes, they will be able to tell. You don't melt pistons on a stock engine. LoL...
Old Oct 11, 2005 | 10:47 AM
Scott (T.O.A)'s Avatar
Default Re: Help...major nitrous damage! (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, they will be able to tell. You don't melt pistons on a stock engine. LoL...</TD></TR></TABLE>
lol
Old Oct 11, 2005 | 10:52 AM
SRCivic97's Avatar
Default Re: Help...major nitrous damage! (Scott (HillRacers))
The dealership denied my claim because I didn't have all my oil changes documented. IE. Did them myself. Even though it was the oil pump on my Y8 that went bad and caused my engine to blow a rod through the block. Later on it was announced that Y8 oil pumps can sometimes go bad. When I replaced the engine with a Z6 I threw the oil pump that was bad through the dealerships managers driverside window and called it a day.
Moral of the story: Good Luck.
Old Oct 11, 2005 | 10:58 AM
VR6 driver's Avatar
Default Re: Help...major nitrous damage! (SRCivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 &raquo;</TD></TR><TR><TD CLASS="quote">I threw the oil pump that was bad through the dealerships managers driverside window and called it a day.
Moral of the story: Good Luck. </TD></TR></TABLE>
No you didn't.
And to the original poster, stop nawsing with a stock engine mang.
Old Oct 11, 2005 | 11:07 AM
SE7EN3S's Avatar
Nitrous on stock internals = Bad idea!
As far as a warrenty... Your friend is F*cked. Sorry man
Old Oct 11, 2005 | 11:21 AM
Mario.'s Avatar
Default Re: Help...major nitrous damage! (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous on stock internals = Bad idea! </TD></TR></TABLE>
Riiiiiight. You keep with that theory. I'll keep spraying.
Old Oct 11, 2005 | 11:38 AM
cockerkid008's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si &raquo;</TD></TR><TR><TD CLASS="quote">My buddy was racing his 99 si a couple weeks ago with a 75 shot of nitrous from a Zex wet kit. His motor is all stock </TD></TR></TABLE>
bingo
Old Oct 11, 2005 | 12:06 PM
hookedonvtec's Avatar
Default Re: Help...major nitrous damage! (cockerkid008)
i know a bunch of people that spray on stock internals, no probs. maybe your buddy was just to fast?
Old Oct 11, 2005 | 12:12 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Help...major nitrous damage! (hookedonvtec)
He probably had something go wrong with the solenoid, or he has a little nitrous left over in the lines, so when he sprayed more than he thought he sprayed came out.
Thats the game you play with nos.
Get a b series longblock, they're cheap 600, and use that.
Old Oct 11, 2005 | 12:14 PM
MugenHonda's Avatar
Default Re: Help...major nitrous damage! (MugenHonda)
Honda definately won't cover it unless you have a hook up somewhere that works for honda
Old Oct 11, 2005 | 12:29 PM
ken00si's Avatar
The car runs, but only on 3 cylinders since #2 is not firing. I think he's gonna rip out the nitrous kit and take it in and try to get it covered under the extended warranty. The car only has 60k miles, he had the 30k checkup and he has record of all oil changes. He was due for the 60k checkup before this, maybe they'll pin that on him if anything.
Old Oct 11, 2005 | 12:41 PM
Jorsher's Avatar
Even if you take the kit out I'm pretty darn sure they'll notice somethings out of place ... Honda engines don't usually screw up like that under normal conditions on pump gas with that low of a mileage.
Tellis234
11
Jul 26, 2007 07:30 PM
ken00si
Oct 11, 2005 04:49 PM
dut
Honda S2000
12
May 19, 2004 02:48 PM
Frederz
May 4, 2004 05:37 PM
blackspoonem
Dec 10, 2003 07:38 PM
