I need the torqe spec for ARP head studs b16 block
Old Oct 11, 2005 | 09:34 AM
JDMlyfestyle's Avatar
Default I need the torqe spec for ARP head studs b16 block
gotta replace my headgasket this weekend but i cant find my ARP torqe sheet and i can never get through when i call.
If my memory serves me correct its 78 ft lbs with the ARP lube.. i have a bottle of the ARP lube here. so can anyone verify this for me.
Old Oct 11, 2005 | 06:05 PM
JDM JEFFREY's Avatar
78 that a lot torge
try 68 or 70
Old Oct 11, 2005 | 09:57 PM
.1type.'s Avatar
Default Re: I need the torqe spec for ARP head studs b16 block (JDMlyfestyle)
first you torqe the head stud to 10lb... second 30lb on the nut.. then again 70lb.. then double check them all...
thatguyjade
Engine Machining & Assembly
Oct 23, 2018 10:36 PM
00CivicSi5spd
Nov 16, 2015 06:57 PM
TypeRbuild718
Sep 27, 2007 08:34 PM
IQ
Dec 22, 2005 06:53 AM
