FS: modified ITR crank pulley (NO AC/PS pulley)
FS LINK to the classifieds: http://hondamarketplace.com/zerothread?id=1399549
im selling my itr crank pulley that has been modified by HT member: owen_the_soyboy. the power steering and ac rib has been precisely machined off leaving only the alternator pulley. looks like a N1 crank pulley but still remains the rubber dampener.
100OBO - never been used.
the pulley only wieghs 2.3 lbs
heres a pic of big teggie (LOOKS EXACTLY LIKE IT BUT ITS PAINTED BLACK)
heres more info on it as well. http://m24x.zeroforum.com/zerothread?id=1244
Modified by imola-red dc2 at 10:45 AM 10/11/2005
Those tooling marks on the crank pulley look as if he used a vertical mill with an end mill to shave off the accessory pulleys! It probably is not that balanced if he used a mill to do that.
this was machined down not cut with a bandsaw and no this pulley is not balanced. it was on my list of things to do, but im changing to a fluidamper pulley for my turbo setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc911 »</TD></TR><TR><TD CLASS="quote">Product
Owen_The_Soyboy Custom Machined Crank Pulley
Manufacturer
Owen_The_Soyboy
Overview
Owen takes your stock OEM crank pulley and machines the extra belt ribs off. You can delete the PS and AC pulley ribs and keep just the alternator rib. With a single rib pulley, the weight is reduced about 50-60%.
The big plus about this pulley modification is that it keeps the stock rubber vibration damper.
Final Comments
Owen has some great mill skills and this is a great service
He charges very little, and to me it is really worth it. All you need to do is go for quick balance after you get it back and you are all set to go.
Here are some pictures of Owens work
Its up the user to the pully balanced it looks like.
Manufacturer
Owen_The_Soyboy
Overview
Final Comments
