question about cams, cam gears, valve springs, retainers SEARCHED
Old Oct 11, 2005 | 08:59 AM
FULLY_BUILT_NA's Avatar
Default question about cams, cam gears, valve springs, retainers SEARCHED
car is 95 gsr hey im planning to upgrade my
cams,
cam gears,
valve springs,
retainers.
im gonna put all these on at the same time and the only thing my car wil have on it is intake, header, and skunk2 manifold, chipped p28
1)will the four things i listed even make any difference? i heard cam gears dont do ****, and i dont wanna put something in that isnt useful
2)is installation basically plug and play? can i let a regular mechanic just swap out everything or do i need to bring it to someone who speciallizes in doing mods?
3)the four things i listed are just from reading. my car will be a DD and i dont wanna go crazy just wanna be able to put some space between all the i/h/e gsr's that try to f with me. i know im get cams for shure, what else do you guys suggest adding or removign from the list of parts?
thanks
Modified by FULLY_BUILT_NA at 10:31 AM 10/11/2005
Old Oct 11, 2005 | 11:09 AM
Gqracer's Avatar
Default Re: question about cams, cam gears, valve springs, retainers SEARCHED (FULLY_BUILT_NA)
cam gears dont do ****, if u dont have any cams
Old Oct 11, 2005 | 01:36 PM
aj95gsr's Avatar
have you thought about rebuilding block and raising comp?
Old Oct 11, 2005 | 06:21 PM
just2post's Avatar
Default Re: question about cams, cam gears, valve springs, retainers SEARCHED (Gqracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gqracer &raquo;</TD></TR><TR><TD CLASS="quote">cam gears dont do ****, if u dont have any cams</TD></TR></TABLE>
well thats why my main thing is cams. do i stil need cam gears then?
my car is a DD so i'd like to keep the engnie in the car and only work on stuff head and above
Old Oct 11, 2005 | 06:50 PM
91' LS-VTEC's Avatar
Default Re: question about cams, cam gears, valve springs, retainers SEARCHED (just2post)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just2post &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, I would install them together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my car is a DD so i'd like to keep the engnie in the car and only work on stuff head and above</TD></TR></TABLE>
Well you can pull off the head and get it milled to raise c/r.
As for the things you listed. Go for it. Get some stage 1 cams and replace your valve train with what ever brand you prefer.
My pick would be a Rocket valvetrain package.
caranjo
Feb 25, 2005 10:57 AM
95BlkGSR
May 7, 2004 07:41 PM
94cd7
Jun 28, 2003 02:01 AM
integraautox
Oct 7, 2002 11:39 AM
Rah Rah
Nov 13, 2001 05:57 PM
