A few steering/brake/cooling problems?!! Suggestions/answers needed.
First off, my steering wheel is turned to the left a little while going straight (top is around 10:30 or 11 o'clock) and when i let go of the wheel on the highway the car pulls to the right. Is this just a needed alignment or should i look for something else?
Second, all of a sudden the rear passenger side brakes squeak on the first braking after sitting for a while and occasionally during normal braking. Pads look fine to me as far as wear. Is this a sign of something??
And third, if i make an 80 mile trip, open the hood and the bottom radiator hose is still lightly warm while the top is scorching hot this is thermostat replacement time right? Any temp rating suggestions or should i get a failsafe one?? I just replaced the radiator with a dual core del sol and bled the system about 5 times for air bubbles.
Thanks for all answers in advance!
first you need an wheel alignment , second is that your brakes are just probably dirty and that it eventually goes away after awhile, and third i think you need to replace the thermostat.
busyychild
Apr 15, 2008 01:25 PM
