ITR Track day Oil Problem
Old Oct 11, 2005 | 01:40 AM
ITR0765's Avatar
Default ITR Track day Oil Problem
Hi guys
This is my first post here but I need some help
I and a friend have a ITR which is mainly used for Track days
The car has at the moment 199,2 WHP NA
Besides several upgradeīs the car has Toda specīs C camshafts, dual valve Toda springs, Toda campulleys, Portflow titanium retainers, Mugen headgasket, etc
The car has a Greddy oil cooler specific kit
We didnīt install as you should the oil temp and pressure gauge
The problem we are facing is that in the exit of two long left corners in the circuit we do, the car makes a lot of white smoke when accelerating hard.
This only happens in those two left corners in the road or in the other corners of the circuit the car donīt have any problem
We need some advise on this because we donīt know what is happening
Thanks
Rui
Old Oct 11, 2005 | 01:46 AM
ITR0765's Avatar
Default Re: ITR Track day Oil Problem (KOALA YUMMIES)
The car has a Mugen Oil Pan too It is baffled
The oil light doesnīt flash at all
Thanks
Rui
Old Oct 11, 2005 | 03:55 AM
jond's Avatar
Default Re: ITR Track day Oil Problem (ITR0765)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0765 &raquo;</TD></TR><TR><TD CLASS="quote">The oil light doesnīt flash at all </TD></TR></TABLE>
I'll probably get flamed for this, but the oil light in the Type-R doesnt work.
Old Oct 11, 2005 | 03:59 AM
Booker's Avatar
Banned Duplicate Account
Default Re: ITR Track day Oil Problem (jond)
It doesn't ?
Old Oct 11, 2005 | 05:32 AM
CW-ITR's Avatar
_Bad PCV valve?
_Running too lean at high RPM?
_Could it be grey or light brown smoke? If so, install a catch can.
_Save this for last...Replace the head gasket.
Old Oct 11, 2005 | 05:40 AM
migs's Avatar
Default Re: (CW-ITR)
Rui, under the hard corners, do you also notice that the vehicle goes out of VTEC?
Old Oct 11, 2005 | 07:47 AM
ITR0765's Avatar
The car has a catch can already
What is the PCV valve???
The smoke is white
The VTEC work perfect and we can feel it
The headgasket is new
The car hasnīt water consumption
There is no trace of oil in the water
Itīs very odd but we donīt know the reason the problem only occurs in two very long left corners
Our mecanich believes itīs a oil pressure problem the oil pump overpressures, but I would like a second opinion
Thanks a lot guys
Rui
Modified by ITR0765 at 9:26 AM 10/11/2005
Old Oct 11, 2005 | 02:51 PM
Big Phat R's Avatar
What gear and what RPM are you on the exit of those corners?
If you exit in a higher gear - do you still get the white smoke?
It's probably crankcase pressure related - (i.e. it's too high)
Old Oct 11, 2005 | 03:16 PM
f1nal zeros's Avatar
Well during hard cornering I agree with koala, you may be getting oil starvation. Why not invest in a acusump oil pump? Atleast this way you have extra oil should it go dry for a moment.
Old Oct 11, 2005 | 04:24 PM
Chris F's Avatar
Default Re: (f1nal zeros)
You're going to learn about the trial user "5 post" limit per day soon.
First off, oil starvation won't cause smoke. It WILL cause bearings to wear and VTEC to disengage (it's oil pressure driven).
PCV= Positive Crankcase Ventilation valve. That valve connects the crankcase breather box (under the intake manifold) to the intake manifold itself (front/center) with a 6" vacuum line. If it was failing, you might suck more oil through there than you'd like.
This is a big/slow download, but I bet your car looks like Ed Sackley's (the CW R with the multicolored fenders). About half-way into the video, he lets out a huge plume of smoke coming through a carousel (180 degree) LEFT turn.
http://www.we-todd-did-racing....DE%3D
Oil will slosh around in your crankcase, and when turning/accelerating, you'll get more oil in the breather box and PCV, and that gets sucked into your intake manifold, and burns a light blue smoke color.
First try a new PCV valve. Also, if you over-fill your oil a bit, this will happen more often.
Last, use a oil catch-can to catch the oil in the PCV before it makes it to your intake manifold.
(this one vents to atmosphere, bad for the environment, and also bad for street driving)
Old Oct 11, 2005 | 05:31 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: ITR Track day Oil Problem (Booker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booker &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't ?
Some people think that the warning PSI is set too low.
Old Oct 11, 2005 | 05:38 PM
H-T Order of Merit
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">You're going to learn about the trial user "5 post" limit per day soon. </TD></TR></TABLE>
He is an unrestricted user.
Old Oct 11, 2005 | 05:42 PM
spoonek4's Avatar
Since u didn't mentioned an upgraded oil pump, would that be that problem at all? OEM oil pump may not work that well after u installed the oil cooler kit?
Old Oct 11, 2005 | 05:47 PM
weezercrx's Avatar
Default Re: ITR Track day Oil Problem (spoonek4)
I had the exact same problem with my car. I installed a catch can inbetween the PCV and stopped it completely.
Old Oct 12, 2005 | 12:39 AM
ITR0765's Avatar
Thanks you are helping a lot
Both corners where this happened are made in 3th gear
First we are going to try the PCV
We are doing the upgrade in the oil pump maybe with a Spoon one anyone with experience on this, what is the best one in the market?
We are about to change the oil pump by an OEM one for precaution
Does anyone knows what level we must put the oil carrying the oil cooler?
You are great guys
Thanks
Rui
Modified by ITR0765 at 2:06 AM 10/12/2005
Modified by ITR0765 at 2:27 AM 10/12/2005
Modified by ITR0765 at 4:46 AM 10/12/2005
Old Oct 12, 2005 | 03:26 AM
Booker's Avatar
Default Re: (ITR0765)
Many people here use the stock B18C5 oil pump for track use w/o problems. I suspect it's something else. But I'm not sure what...
Old Oct 12, 2005 | 04:15 AM
H-T Order of Merit
We are doing the upgrade in the oil pump maybe with a Spoon one....
We are about to change the oil pump by an OEM one for precaution</TD></TR></TABLE>
I don't think you're on the right track here. The oil pumps last a long time, and even if one is wearing I don't see how it could be causing your momentary smoking problem.
Do you think you're putting too much oil in? That you're overcompensating for the addition of the oil cooler?
Old Oct 12, 2005 | 04:41 AM
ITR0765's Avatar
Default Re: (George Knighton)
Thatīs one of the problems we are faccing we donīt know if we should maintain the max level for the oil using the oil cooler
We were changing the pump only by precaution, and because itīs not too expensive
Thanks
Rui
Old Oct 12, 2005 | 04:44 AM
H-T Order of Merit
Let's see if one of the Honda Challenge people can answer the question about oil level with the oil cooler.
Old Oct 12, 2005 | 07:34 AM
Dr Pooface's Avatar
Oil level w/cooler: I fill the engine with 4 liters, and then idle it for 5 mins. Then I check the dipstick and fill as necessary until it reads full (ie halfway in between the lines= add 1/2 liter). Takes about 5.3 liters with a filter change on my car.
Old Oct 12, 2005 | 08:05 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booker &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't ?</TD></TR></TABLE>
I've never had mine come on. EVER. Not even the first few seconds after an oil change.
I would bet $5 you could run a ITR with no oil at all and the thing still wouldnt come on.
Old Oct 12, 2005 | 03:31 PM
mugenracer's Avatar
My oil ight comes on when you start the car.
After an oil change it takes a second or two to go out...but it does came on, just not when driving.
Old Oct 12, 2005 | 04:32 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
Most oil pressure lights are set to come on at really extremely low pressures.
It used to be a joke back in the old FIAT Abarth days that the twincam motors had oil pressure lights that wouldn't come on until about 3 psi.
It'd only worry you if you were under load and that happened. A lot of those old motors would idle w/the light on and the gauge reading close to zero, but they'd climb to 45 psi under load. So nobody worried.
Maybe it's possible that your particular modern Honda motor just never gets down around 3 psi, even right after an oil change. (?)
Old Oct 13, 2005 | 12:07 AM
petrv's Avatar
Default Re: ITR Track day Oil Problem (George Knighton)
I assume that thanks to the oil pickup design, the oil starvation can occur only in left turns (when the oil moves to the right side and the pickup is on the left side) ?
Old Oct 13, 2005 | 03:18 PM
ITR0765's Avatar
Default Re: ITR Track day Oil Problem (petrv)
But this shouldnīt happened with a Mugen oil pan
Rui
