What the hell do i have to do?
Old Oct 11, 2005 | 01:35 AM
cmyrex's Avatar
Default What the hell do i have to do?
So basically i have a tired Zc that was turbo and is out of the car we swap in a sohc d15b from a 92-95 civic everything runs fine except for at low idle rpms it smokes white. The head gasket has been changed and it stills smokes, oil is crystal clear not milky or anything. I am about had it with this car. I am about to roll it off a cliff . Me and my friends have worked on it for four days straight that has been since we did the swap so in order it goes like this. First day engine was swapped in Si trans went in car doesnt start trannies diff is broken and stuck in gear. Day two swap in another tranny its too late to get the parts for the car. Day three start the car it throws a crank angle sensor code, distributor bad we fix it get a new dizzy and run the right sohc ecu no check engine lights car smokes white from the down pipe. Day four i take all the turbo crap off and run in NA for today we check cylinder's 4 is soaked in oil and the others are not to bad. We start it and still it smokes white and it smells like maple syrup so we pretty much know that what it has been smoking is coolant it has a vapor type smoke to it. We change head gasket and still it smokes but only at low idles and when i am at a dead stop when i am driving it, it does not smoke it also decided to throw a coolant temp check engine light (code 6) for some reason. Why is my car giving me problems man. I love my rex to death but this is ridicolous. We are coming to the conclusion that it may be a cracked head. We have a d16y something i forgot what it is i believe it is non vtec head. The engine came off a ek 4 door. If possible am i able to put the 1.6 head from the d16 on my d15b which came out of a eg four door? Is there something more drastic with this engine that i am missing. If it is the head what parts do i need to do this setup and Is this something that is even possible. I am at the mercy of my crx this is my dd i need it to be fixed asap. I am getting frustrated at this car. Is there something wrong with the parts i am using i know my car is kinda of a frankenstein. Are the lines on the manifold ran right? . Any of your comments,input, and advice to what my car is doing will be helpful and greatly appreciated thanks.
Here is my setup
d15b from a eg coupe
ef Si intake manifold and fuel rail.
si dizzy si ecu
si manifold
zcsport
May 21, 2007 09:04 AM
I got a honda
Jun 25, 2005 11:02 PM
CimorelliCRX
10
Jan 12, 2003 04:58 PM
TypeR0207
19
Jun 19, 2002 06:23 AM
