Stock z6 FPR on y7?
Old Oct 10, 2005 | 11:21 PM
Ax3l's Avatar
Default Stock z6 FPR on y7?
Hey,
Got a d16y7 engine and did a z6 IM swap on it, so my setup is like -
-(d16)z6 IM, Fuel Rail, FPR
-y7 TB, Injectors, ECU, etc, etc...
So, my question is, will the stock z6 FPR deliver too much pressure for my y7 engine/ecu/injectors? I used it because the y7 FPR did not fit the z6 Rail.
Anyone know the differences in the stock d-series FPR's? Should i get an adjustable FPR and a gauge to adjust it to (d16y7) factory spec?
-Thanks.
Old Oct 11, 2005 | 02:44 AM
Ax3l's Avatar
Bump -
Old Oct 11, 2005 | 10:10 PM
Ax3l's Avatar
Default Re: (Ax3l)
2nd day bump.
Old Oct 11, 2005 | 10:33 PM
ironcheftony's Avatar
should be the same
Old Oct 11, 2005 | 10:48 PM
Ax3l's Avatar
even though it's differend obd's and the y7 fpr has a different design, so i does not fit a z6 rail?
Should be the same psi on both?
AlfieRoach
Jul 20, 2011 03:18 PM
jonleeone
Jun 23, 2005 02:20 PM
shbrown
Jun 4, 2005 01:15 PM
StealthSol
Apr 13, 2005 06:07 PM
onePOINTsix
Aug 26, 2003 12:58 PM
