fuel pump
Old Oct 10, 2005 | 09:06 PM
mattlovescindy95's Avatar
Default fuel pump
hey i have a 99 si, with I/H/E type r camshaft and was going to run a walbro 255lph fuel pump and rc injectors my question is what size injectors should I run
Old Oct 10, 2005 | 09:17 PM
Luserkid's Avatar
Default Re: fuel pump (mattlovescindy95)
Stock, along with the pump. Unless if you really build then you dont have a reason to change those.
Old Oct 10, 2005 | 10:26 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: fuel pump (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Stock, along with the pump. Unless if you really build then you dont have a reason to change those. </TD></TR></TABLE>
i'm still running stock fuel pump o\from my 92 civic vx and i've got over triple stock horsepower.
yay honda.
if you have a chipped ECU and a wideband you'll see that when you're at prefect air/fuel, even at 100% throttle and redline you're probably not even in the %90s on injector duity cycle.
Old Oct 10, 2005 | 11:09 PM
civic_driver's Avatar
hey mike, what size injectors does the h22 have stock?
Old Oct 14, 2005 | 06:42 AM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (civic_driver)
345s
Old Oct 14, 2005 | 06:50 AM
SkoundrelUSA's Avatar
cute little bastard
Don't waste your money fool!
If yours is busted get another stock one or 190 at most
Old Oct 14, 2005 | 07:37 AM
Aquafina_Powered's Avatar
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">345s</TD></TR></TABLE>
only on the 92-96
Old Oct 14, 2005 | 09:05 AM
EGmikeH22's Avatar
* B A N N E D *
yes, and the OBD2 engines I believe are 290s.
Old Oct 14, 2005 | 09:06 AM
JDM-EJ1's Avatar
Exactly. With your setup, there's no need for that.
lassek20
Jul 9, 2012 02:58 PM
Ruben19
Jan 27, 2006 12:48 PM
blksiryder
Jun 17, 2004 10:53 AM
jeremy.
Sep 29, 2003 05:35 PM
