Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Nitto NT01
Old Oct 10, 2005 | 09:02 PM
RagingAngel's Avatar
Default Nitto NT01
A friend of mine was poking on the Nitto site and "discovered" these new tires and thought you guys might be interested in them.
From the Nitto site: http://www.nittotire.com/tires_nt01_features.asp
Here's a brief article I found while searching on HT.
http://popularhotrodding.com/tech/0511phr_tire/
Discount Tire direct also has them in stock now:
http://www.discounttiredirect....ar=50
Anybody wanna be the guinea pig?
Old Oct 10, 2005 | 10:02 PM
Booker's Avatar
Banned Duplicate Account
Default Re: Nitto NT01 (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The great thing about a tire company that gets involved at the grassroots level is that you invariably end up with sizes that are just right for your market--as opposed to a bunch of exoticar sizes nobody needs. (You won't find "bling" sizes either.) A look [b]at the NT01 size chart reveals that this tire is designed predominantly for heavier bread-and-butter musclecars.[b/b]</TD></TR></TABLE>
Unless there is some one using a RWD V8 here I'd wait til they designed and tire for the FWD 4cyl weekend crew.
Old Jan 5, 2006 | 02:40 AM
SnlpeR's Avatar
Default Re: Nitto NT01 (Booker)
mounted them tonight
gonna test them out on an autox event in a couple of days
other tires on the rack are the new Federal 595RS
Old Jan 5, 2006 | 12:13 PM
bad-monkey's Avatar
these are the tires that the GRM guys helped the nitto design team out with, yes?
Old Jan 5, 2006 | 12:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">these are the tires that the GRM guys helped the nitto design team out with, yes?</TD></TR></TABLE>
I don't think so. It sounds like you are referring to the advice provided by the Popular Hotrodding guys (see link to article, above) rather than the Grassroots Motoring guys. If GRM helped, I think you would see a lot more tire sizes for smaller wheels; as the article notes, the sizes produced are instead geared towards the muscle car set.
Old Jan 5, 2006 | 11:10 PM
SnlpeR's Avatar
first 10 mile experience...
all street driving and going speed limits
noisy! humming begins as slow as 25mph
harsh.. (42/40 f/r psi)
fairy responsive for the speed i was going
overall....i like..i like
cant wait till sunday
Old Jan 6, 2006 | 05:41 AM
emwavey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Anybody wanna be the guinea pig? </TD></TR></TABLE>
Also on discount direct tire, they have an unfamiliar (to me) wheel offered called simply "Competition".
http://www.discounttiredirect....4-100
However in searching for "real" data, namely the weight, neither Discount Direct, nor MB Wheels, the manufacturer, has it posted. The pdf file at MB Wheels simply has the weight listed as N/A. How about SOL? That would make more sense right? It doesn't look promising though, judging by the other wheels listed within their "Motorsports Wheel Specifications" section.
http://www.wheelsbymbmotoring....s.pdf
To give them the benefit of the doubt, I emailed them to find out what the weight is, and I'll be glad to pass that information along IF I get it.
Old Jan 6, 2006 | 08:03 AM
bad-monkey's Avatar
i believe when i looked at that particular wheel, it was pretty f'in heavy. 21.3 lbs in a 17x7. i don't remember where i got the info on it though.
i'm guessing a 15 would be 16 lbs or so.
Old Jan 6, 2006 | 11:37 AM
emwavey's Avatar
I received and email back. They are 13 lbs.
... started a new thread:
https://honda-tech.com/zerothread?id=1484556
Sorry for siderailing this thread.
Old Jan 6, 2006 | 02:13 PM
Red 5's Avatar
Default Re: Nitto NT01 (emwavey)
Those wheels look like the Final Speed Hyper Cast wheels from this company (minus the stickers) http://www.hotstuff-cp.co.jp/p...ct=20.
Old Jan 6, 2006 | 03:00 PM
PINEAPPLE's Avatar
those tires look decent. I am also curious about the federal 595rs. SnIper update us when you are done testing them.
Old Jan 6, 2006 | 07:46 PM
Vracer111's Avatar
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">first 10 mile experience...
cant wait till sunday</TD></TR></TABLE>
That tire pressure seems too high! I run the Nitto NT-555RII (275/40-17) at 34psi front and 32 psi rear with around a 3380lb total weight. Now the new NT-01 might be a different tire, and you are using a smaller diameter/higher profile tire. But the Nitto NT-555RII's usually run best in the low-mid 30psi range on large heavy cars...And my Camaros ride is smoother than my brothers Integras (205/50-15 Hankook R-S2 Z212 at daily driver pressure 35psi F/ 30 R) yet responds just as fast, holds a lot more G's, and actually is faster at autocrosses.
If the NT-01's are an improvement on the NT-555RII then you will like them - Grip! (well it's an R-compound tire, duh!), good wear characteristic (2 track weekends, 2 evolution schools, over half a dozen autocrosses, ~2000 miles on the road and now they are just to the wear bars yet still sticky as ever), daily drivable, and very decent wet performance. The only thing about the NT-555RII is the steering response - they are slower than 245/50-16 Yokohama ES-100s in that regard. The NT-01's are supposed to be better in steering response though.
Old Jan 7, 2006 | 02:20 AM
SnlpeR's Avatar
i actually drove the car with 30psi for a little bit..
response sucked...but soaking up little bumps ont he road was good
i didnt care for the latter so i inflated to 42f
its got a similar feel to the kumho ecsta v700
you can throw anything at it and it would take it easily
yank hard on the wheel and itll yank you back on the seat
ill try it out tomorrow at our autox event
ill prolly get 15-20 laps on a minute long course
Old Jan 8, 2006 | 06:26 PM
David S. Wallens's Avatar
That's probably a bit of an overstatement, but when Nitto was in the early planning stages for the NT-01 we all went to lunch at Chili's. We discussed popular cars, SCCA, NASA, stuff like that. Neat to see the tire out now, a couple of years later. I think they have some more ideas in the works, as they have been asking more questions. We had a good meeting at the PRI Show, and the Nitto guys spent a lot of time talking with the SCCA's Howard Duncan.
X12
Apr 4, 2005 02:40 PM
4-banging
Jun 14, 2004 01:56 PM
SystemGSR
Mar 25, 2002 08:53 PM
YellowR2000
Feb 26, 2002 02:28 PM
KF_S2000
Nov 26, 2001 09:24 AM
