Jun ITB H22 hp.......Sound right
Old Oct 10, 2005 | 08:11 PM
towvtec's Avatar
Default Jun ITB H22 hp.......Sound right
Just got our car dynoed 211hp and 153tq sounds right
H22
Stock bottom end
Jun stage 3 cams and springs
Titanium retainers
Rev valves
Port & Polish by BCE
TWM ITB
310cc injecter
255 pump
F.A.S.T tuned by R & D
on C16
Modified by towvtec at 9:44 PM 10/10/2005
Modified by towvtec at 10:19 PM 10/10/2005
Old Oct 10, 2005 | 08:16 PM
DxTrix's Avatar
Default Re: Jun ITB H22 hp.......Sound right (towvtec)
You forgot it was detonating on cylinder 4
Old Oct 10, 2005 | 08:20 PM
towvtec's Avatar
Default Re: Jun ITB H22 hp.......Sound right (DxTrix)
that too...
Old Oct 10, 2005 | 08:41 PM
DxTrix's Avatar
We always thought the injectors were 440s till we pulled them out to have them cleaned and found out they were 310s
Old Oct 10, 2005 | 08:47 PM
TylerH's Avatar
It looks like once you hit vtec your power bounces down for a couple rpms and then back up you might want to change your vtec setting maybe it will smoothing out.
Old Oct 10, 2005 | 08:53 PM
JDogg's Avatar
Default Re: Jun ITB H22 hp.......Sound right (TylerH)
why are you running c16?
Old Oct 10, 2005 | 09:00 PM
DxTrix's Avatar
Default Re: Jun ITB H22 hp.......Sound right (JDogg)
Just cause we had a bunch of it....What fuel would you recomend?
Old Oct 10, 2005 | 09:07 PM
JDogg's Avatar
more octane does not = more hp..
most id try to run would be 100 octane, you should be able to reach mbt with 93 no problem.
just for comparison... we did 217 with euro r intake manifold, jun3 cams, crap header, stock head, aem ems. it was pulling to a little over 8500
Old Oct 10, 2005 | 09:11 PM
DxTrix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">more octane does not = more hp..
just for comparison... we did 217 with euro r intake manifold, jun3 cams, crap header, stock head, aem ems. it was pulling to a little over 8500</TD></TR></TABLE>
We know more octane does not equal more hp we just had the fuel so we decided to use it. What other recomendations would you give use to do?
Old Oct 10, 2005 | 09:17 PM
DxTrix's Avatar
Pics of the engine bay have also been posted up.
Old Oct 11, 2005 | 05:29 AM
.nate's Avatar
Do you have a dynograph spraying?
Old Oct 11, 2005 | 06:22 AM
iakona's Avatar
i'd like to see the duty cycle on those injectors and your fuel pressure at the rail.
and how do those TWMs run only on 10.6 CR?? that's been my only big hang up; not enough CR.
Old Oct 11, 2005 | 10:41 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix &raquo;</TD></TR><TR><TD CLASS="quote">You forgot it was detonating on cylinder 4</TD></TR></TABLE>
It's still detonating after the new injectors?
Seems to like the juice though
Old Oct 11, 2005 | 11:01 AM
flyrod's Avatar
If it was detonating on race gas, then it would be worse on lower octane, right? It doesn't seem like that setup should detonate at all though... Thanks for posing your setup and dyno!
Old Oct 11, 2005 | 02:59 PM
towvtec's Avatar
Default Re: Jun ITB H22 hp.......Sound right (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Seems to like the juice though </TD></TR></TABLE>
we just installed bigger injecters & we are going to dyno/tune this week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a dynograph spraying?</TD></TR></TABLE>
286hp spraying-its on the dynograph in green
Old Oct 11, 2005 | 03:33 PM
Combustion Contraption's Avatar
Shouldnt be detonating with that low of a CR, unless youre speaking of under nitrous-ed conditios and still not with c16. I think youll see a dramatic increase in power by switching to 93 octane so you get full burn effect on the power stroke , and by fixing whatever problem it is your having with cylinder #4.
Old Oct 11, 2005 | 03:52 PM
VSBB6's Avatar
FYI, I made 206whp & 164tq on dynodynamics with Jun cams, TWM ITBs, AEM EMS, SMSP header, UR pulleys, USDM stock head/bottom end.
If you want dynojet figures, that would be approximately 226whp.
Old Oct 11, 2005 | 04:10 PM
towvtec's Avatar
Default Re: Jun ITB H22 hp.......Sound right (VSBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">FYI, I made 206whp & 164tq on dynodynamics with Jun cams, TWM ITBs, AEM EMS, SMSP header, UR pulleys, USDM stock head/bottom end.
If you want dynojet figures, that would be approximately 226whp.</TD></TR></TABLE>
what gas were u runin? if u dont mind.....
Old Oct 11, 2005 | 04:11 PM
Viorent Grip! EG's Avatar
how much nitrous are you shooting on the dyno?
power however does seem low in my opinion....try 440cc injectors yet?
Old Oct 11, 2005 | 04:58 PM
DxTrix's Avatar
Default Re: Jun ITB H22 hp.......Sound right (Viorent Grip! EG)
100 shot and we just got some biggr injectors but have not made it to the dyno yet
Old Oct 11, 2005 | 05:53 PM
how is your air fuel ratio?
can u tell if ur starving of some fuel?
and i assume all of this is on a healthy motor...
good luck with retuning with bigger injectors..
Old Oct 11, 2005 | 05:55 PM
Honda318dx's Avatar
310s is not enough injector..
Old Oct 11, 2005 | 08:01 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towvtec &raquo;</TD></TR><TR><TD CLASS="quote">
286hp spraying-its on the dynograph in green</TD></TR></TABLE>
good
Old Oct 11, 2005 | 10:00 PM
VSBB6's Avatar
I was running 94 octane.
what gas were u runin? if u dont mind.....</TD></TR></TABLE>
Old Oct 12, 2005 | 06:28 AM
mgags7's Avatar
dispute results however you may, but on rlz's dynapack, which they say is somewhere from 10-20% lower than a local dynojet, i put down 183whp and 140wtq.....
add 10% = 201whp and 154 ft lbs
add 12.5% = 206whp and 156 ft lbs
thats with only a j's racing intake, a rmf mild build header, and a catback, stock jdm h22....tuned on an s200....
just to provide a sense of how low that thing reads....stock h22s put down about 130-140max on their dyno, and are well known to put down 165-170 on dynojets....thats about 25% off...but i wont be that ambitious, that would put me at like 230whp....
take it how you see it, im not claiming anything....just for info....
with stock compression, you should be running pump gas....
pop that motor back out, and throw some f22/h23 rods and crank in there, with type s pistons....that will put you at a bit over 12:1 and bump the stroke a good bit...then you probably could see benefits from the race gas, but either way, it would pick up huge hp numbers....
oh and if thats an anr header, a switch to an smsp or an rmf would show some real good gains....
