Taking off the Valve Cover DX ***Need Help***
I know how to take off the Valve Cover thats not the problem. I know I need a Vavle cover gasket. I need to know all the Gaskets I can replace once the Valve cover is off. I want to replace them all while it's off. I know there are the ones for the Spark Plug Wires but I forget what they are called. If anyone can tell me all the ones I can replace while the Valve cover is off would help me out a lot. Thanks.
Ok, those are spark plug tube seals and the other things you need are valve cover gromets and of course the valve cover gasket. That is pretty much it. maybe while you in there, you should adjust the valves.
standbackimapro
Apr 29, 2006 05:38 PM
HONDA-2NR
18
Mar 7, 2004 07:13 PM
