LCA's will ek lca's from an si fit on a EG hatch?
If they fit, which I am sure they will, you will need to use the EK shocks for the EK LCAs. As far as the GSR swaybar, not too sure if it will fit.
No they don't fit. EK LCA's are longer than EG and DC LCA's. You can swap DC LCA's onto your EG though. Even if you get the EK ones to work, you'll probably have some massive negative camber.
LSEGHATCH
Sep 4, 2006 03:18 PM
