Suspension & Brakes Theory, alignment, spring rates....
WARNING: STUPID QUESTION!!!
Old Oct 10, 2005 | 03:52 PM
hypeR speed's Avatar
Default WARNING: STUPID QUESTION!!!
i know this is a retarded question but i would want a definite answer .... here goes ::flame suit on::
what would happen if you took off ur front sway bar? is it possible for the suspension to act normally? or would you just have maaassive body roll?
reason i ask i have a theft-recovery itr and the handling just isn't great. haven't checked under the car to check if i actually have em buut it just feels very loose, nothing like what i expected. my friend who had an itr before it got stolen even said my car feels like ****, and he recently drove a 98 itr stock everything, w/ 130k miles and said that car felt totally awesome, nothing compared to mine.
now my suspension is stock itr not blown shocks, no suspension mods except a cusco front lower tie bar and a jdm rear tower bar. i'm planning on getting the jdm itr f/r sways, but just incase that doesn't alleviate the problem, what can I do to make my car handle like a real R? would alignment affect the overall feel of the suspension if it were slightly off?
Old Oct 10, 2005 | 05:03 PM
cultwagen's Avatar
if a suspension is designed to work with sway bars then it would have substantial lean and not feel very solid in the corners.
it is possible to design a suspension with super high spring rates that releaves the need for sway bars. just depends on what setup you like.
have you checked your alignment?
Old Oct 10, 2005 | 06:13 PM
Default Re: (cultwagen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cultwagen &raquo;</TD></TR><TR><TD CLASS="quote">
have you checked your alignment? </TD></TR></TABLE>
no not yet, i know i should but im waiting for some bolts to my rear upper control arms before doing an alignment.
Old Oct 11, 2005 | 02:17 PM
gabebauman's Avatar
Default Re: WARNING: STUPID QUESTION!!! (res09ggm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by res09ggm &raquo;</TD></TR><TR><TD CLASS="quote">I have a theft-recovery itr and the handling just isn't great.</TD></TR></TABLE>
It's possible that the thieves ditched/wrecked it and messed up some the suspension components. I'd be sure to take it to an alignment shop and have it checked out. Good luck.
Old Oct 11, 2005 | 10:06 PM
:Andrew's Avatar
Default Re: WARNING: STUPID QUESTION!!! (gabebauman)
i agree on checking the camber/alignment cause if the only thing that is missing is the front sway bar it should not be a huge difference in handling
Old Oct 12, 2005 | 12:41 PM
intevic_dx's Avatar
not having a front swaybar would make the *** end want to step out. its a trick i learned from drifting.
Old Oct 12, 2005 | 04:03 PM
well it seems i can't do an alignment at a shop because of liability issues. I told them two bolts for the upper control arm to the rear body arent torqued down correctly. the thread on the body seems to be f*cked because try all i might, the damn bolt wont go in flush.... theres about 4 millimeters left between the body and the control arm. soooo i ordered some new bolts from acura hoping that maybe the previous owner tried putting on wrong ones... i can only hope... currently everytime i go over a hard bump the arm hits the body and theres a loud click.. can get pretty annoying while driving over train tracks.
SGVridgerunner
Oct 19, 2006 11:13 AM
Transport
10
May 12, 2004 07:04 PM
tan2
Nov 18, 2003 03:02 PM
yoda888
Nov 13, 2003 07:47 AM
DI9ITAL
Mar 25, 2003 09:42 AM
