Squeaking Camber Kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99 »</TD></TR><TR><TD CLASS="quote">I have an Ingalls front and rear camber kit w/rubber bushings that are squeaking and annoying the hell outta me. Any fixes recommended?</TD></TR></TABLE>
My polyurethane Ingalls front kit squeaks something fierce, but once I'm moving the drone of the tire noise drowns them out.
Recommended fixes (I'm no expert here, but here goes...) would be to verify that you do indeed have rubber and polyurethane, start by checking the part number if you can. This shouldn't matter, but I suppose if you didn't preload the suspension it could cause it, since the rubber would already be under stress just sitting on the ground and put under further stress than normal from suspension movement. And there's always grease if nothing else seems to work.
matt94z
19
Aug 8, 2008 06:14 AM
95slomocivi
Feb 23, 2006 03:48 PM
-slow ej-
10
Jun 4, 2003 08:42 PM
