itr or RS brake swap
Old Oct 10, 2005 | 03:30 PM
mugen94's Avatar
Default itr or RS brake swap
hi I have a 91 civic si hb. and i want to have brake from itr.. in front and rear i think i can use the rear arm from a 90-93 integra i wan to know exaclty what is the piece i need to buy thanks you
Old Oct 10, 2005 | 04:20 PM
EL Vap133's Avatar
Default Re: itr or RS brake swap (mugen94)
It would be cheaper to go with plain ol' Teg brakes. Oh and use your stock LCAs.
Old Oct 10, 2005 | 06:57 PM
DC_RaceR's Avatar
Don't you already have disc in the back with the SI?
Old Oct 11, 2005 | 01:08 PM
EL Vap133's Avatar
Default Re: itr or RS brake swap (DC_RaceR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">Don't you already have disc in the back with the SI?</TD></TR></TABLE>
No, the 88-91 Si hatch never came with them from the factory. Only the 90-91 CRX Si did.
Old Oct 11, 2005 | 02:21 PM
jdmef1991's Avatar
I'm a Jackass
i would suggest to do the integra rear disc swap because its a bolt on same with the ITR but would you like to have 5 lugs in the rear and 4 on the front? plus replacement parts for a DA rear brakes are not as much as ITR's and make sure you get the rear brake lines for the disc the ones for your drums are different good luck with your swap
racingcrx
Nov 22, 2008 03:43 PM
CRX 2.0V-T
Oct 10, 2006 07:25 AM
SPL KID
Apr 26, 2005 03:55 PM
aVstAr
12
Nov 30, 2003 05:59 PM
91_hatch_si
Dec 30, 2002 09:19 PM
