how to install clutch???? urgent
Old Oct 10, 2005 | 12:46 PM
blkhatch92's Avatar
Default how to install clutch???? urgent
i need step by step instructions to install civic clutch for 92 civic dx hatch i looked everywhere and i cannot find nothin so plz help a link or somethin would be nice thx
Old Oct 10, 2005 | 12:58 PM
TeamNextGenChris's Avatar
Default Re: how to install clutch???? urgent (blkhatch92)
you need to go to any local auto part store and buy a $10 shop manual.it outlines the procedure.
even better,spend a little more and get a Helm manual.
Chris
Old Oct 10, 2005 | 01:02 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: how to install clutch???? urgent (TeamNextGenChris)
I'll give a quick run down since I am a nice guy today, lol
1st, take off the front wheels, jack up your car securely using jack stands.
Next, remove the lower ball joint nut, and then take off the strut.
Pull strut out, take axle out.
Get a jack under the tranny for leverage, and attempt to take the mounts out.
Then take off the screw connecting tranny to engine.Take off slave cylinder and all necessary wires connecting tranny to engine harness.
When you pull the tranny out, everything else should be self explanatory.
Torque flywheel to 90, pressure plate to 80lb fts.
grease up the throwout and tranny shaft very good or you will hear squeaks later down the road
Old Oct 10, 2005 | 01:06 PM
blkhatch92's Avatar
thx for the info and also i bought a helms manual thx
Old Oct 10, 2005 | 01:07 PM
blkhatch92's Avatar
what type of grease would be recommended for the throwout bearing???
Old Oct 10, 2005 | 01:08 PM
Default Re: how to install clutch???? urgent (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">
torque the pressure plate to 80lb/ft and you'll have big problems.off the top of my head,the specs are closer to around 20lb/ft.
BTW-a simple search for "clutch install" on here provides tons of useful info,such as:
https://honda-tech.com/zerothread?id=1282117
https://honda-tech.com/zerothread?id=923640
Chris
JDMlyfestyle's Avatar
I should be doing this write up in about a week :-D
Old Oct 10, 2005 | 01:10 PM
kkim's Avatar
http://www.c-speedracing.com/h...h.php
Old Oct 10, 2005 | 02:13 PM
FullJDMEg's Avatar
yes 20 to 30 sounds a lot beter i have 94 hb dx and i tq mine th 27 and works and sounds good
kenzo42
Oct 30, 2008 07:02 AM
PINKS
13
May 13, 2007 12:39 PM
integraGSR213
Feb 9, 2004 03:16 PM
team2n1hatch
Dec 2, 2003 09:24 PM
R-gonaut
May 24, 2003 05:43 AM
