Q about the J1 tranny?
Old Oct 10, 2005 | 12:34 PM
AZTEKEF9's Avatar
Default Q about the J1 tranny?
well i was reading honda-tuning and this is what i read about the J1 tranny...
"the J1 is a great tranny and will be far better than the LS. the Y1 limited-slip differential will fit in the J1 if u use the y1's countershaft. You could also use the type r limited slip diff if u put a 4.40 final drive on it to make it fit. there is no way to fit a larger final drive (such as a 4.7) in the J1 case without serious modification to the case. you'll want to use a 90-91 integra clutch with the J1, the 92-93 clutch will not fit. by DB."
what else can i upgrade on my J1 tranny?
Old Oct 10, 2005 | 01:54 PM
Sgt_Ox's Avatar
Default Re: Q about the J1 tranny? (AZTEKEF9)
part of it doesn't make sense. I've read on here at HT that you can put in the Y1 LSD's and keep the J1 4:40 final drive, all you have to use is the ring gear from the J1's differential. Why would you want to go through all that trouble to make your J1 with a 4.40 FD brought down to a 4.26 FD from the Y1's? Unless you want to turbo the car and mess with the gearing, but even then .....I dunno I'm stumped.
Old Oct 10, 2005 | 02:36 PM
AZTEKEF9's Avatar
Default Re: Q about the J1 tranny? (Sgt_Ox)
well i got the J1 pretty cheap... so i wanted to upgrade with oem parts. also i'm still looking into whether turbo or all motor.
what else fit into the j1 casing?
Old Oct 10, 2005 | 04:21 PM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">well i got the J1 pretty cheap... so i wanted to upgrade with oem parts. also i'm still looking into whether turbo or all motor.
what else fit into the j1 casing?</TD></TR></TABLE>well my suggestion would first look into upgrading the differential. The stock diff in that J1, S1, and non LSD Y1's are a ticking bomb.
I had a J1, and quote that I "had" since the diff pin gave out on my and sent the spider gears bursting out of the casing while on the freeway doing 75mph.
The weakest link in that tranny is the non-hardened diff pin (unless you already have LSD).
Old Oct 10, 2005 | 04:27 PM
jisu009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sgt_Ox &raquo;</TD></TR><TR><TD CLASS="quote">well my suggestion would first look into upgrading the differential. The stock diff in that J1, S1, and non LSD Y1's are a ticking bomb.
The weakest link in that tranny is the non-hardened diff pin (unless you already have LSD). </TD></TR></TABLE>
Bingo!! My pin gave out also and the pinion slid out of the diff and tore the case apart.
Old Oct 10, 2005 | 10:21 PM
jpciii's Avatar
Oh dear... My S1 being torqued by my big B20 could blow up, eh? Now I'm scared. I don't know much about trannies... other than getting a limited slip, is there another way (read: cheaper way) to fix this potential problem?
thanks
Old Oct 10, 2005 | 11:18 PM
SiR Inspired ED7's Avatar
My j1 tranny is treating me good so far.
Old Oct 11, 2005 | 05:10 AM
Sgt_Ox's Avatar
Default Re: Q about the J1 tranny? (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">My j1 tranny is treating me good so far.</TD></TR></TABLE>I loved my J1 until it exploded then I bought a YS1. I've yet to drive the car with the ITR LSD installed.
Oh yeah while you're at it might as well replace the synchros. That's my suggestion though.
Old Oct 11, 2005 | 06:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
Call Gear-Speed...they can tell you what you can and can't do, and they have a line on just about any part you could dream of putting in your transmission. They are a little on the steep side though, but they do good work.
mrx
18
Feb 25, 2013 05:21 AM
cursED
Apr 9, 2007 04:18 PM
kuki
Apr 9, 2006 01:56 PM
water
Mar 18, 2004 10:37 AM
Spoon Si
Sep 30, 2002 09:33 AM
