Welding in a 8 point cage in a Ek Hatch
Old Oct 10, 2005 | 12:30 PM
fracas's Avatar
Default Welding in a 8 point cage in a Ek Hatch
I just bought a 8 point S & W cage for my Ek. What I was wanting to know is there anyone out there with Pix of there cage welded in. I need to know how to have the plate's welded in and where the bars need to welded on the hoop. Im not welding this together. Im taking it to a Welding shop. I just want to know whats going on before the welder does his job.
Any and All info is needed for the project. This is my 1st cage.
Old Oct 12, 2005 | 05:38 AM
fracas's Avatar
It looks like Im going to have to Jump over the Door bar!!! Hahahahahah
So did you have any issues with putting it together?
Old Oct 12, 2005 | 05:46 AM
tony1's Avatar
Default Re: Welding in a 8 point cage in a Ek Hatch (NAPIER)
I just finished installing an S&W cage in a VW. Don't kid yourself, there's ALOT of fitting and work to be done. Going with that pre bent cage probably saves you 2 hours out of the whole project.
Old Oct 12, 2005 | 05:52 AM
fracas's Avatar
Pm'd you Tony1
Old Oct 12, 2005 | 07:13 AM
Race Egr's Avatar
Default Re: (fracas)
yea tony 1 is most def right, it takes alot of fittin work to get it all in there. Btw thanks tony for all the help
Old Oct 12, 2005 | 11:48 AM
slammed_93_hatch's Avatar
i dunno maybe its just that picture, but htat roll bar looks to have at leat 4 inch of room between the mainhoop and the car. Is it just camera angle?
Old Oct 12, 2005 | 12:06 PM
tony1's Avatar
Default Re: Welding in a 8 point cage in a Ek Hatch (slammed_93_hatch)
The one i just installed is the same way, can't expect much more than that from a pre bent cage most of the time. I'd recommend to spend a little extra and get a custom cage done, it'll fit much better.
Old Oct 12, 2005 | 02:21 PM
XtremeMotorWerks's Avatar
I agree we are installing one now and personally i think it takes more work installing a pre bent. you basically have to hold ever peice in the car to make sure the main hoop is in the right place so you have enough room to notch the other peices such as the piller bars and rear tree down tubes.
I also think it personally fits like ****, the notches are burned out and not to close to fitting the way i would like. definatly easier and much nicer to just fab on up custom.
Old Oct 12, 2005 | 03:12 PM
Default Re: Welding in a 8 point cage in a Ek Hatch (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">The one i just installed is the same way, can't expect much more than that from a pre bent cage most of the time. I'd recommend to spend a little extra and get a custom cage done, it'll fit much better.</TD></TR></TABLE>
that passes tech?
Old Oct 12, 2005 | 05:35 PM
tony1's Avatar
Default Re: (XtremeMotorWerks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeMotorWerks &raquo;</TD></TR><TR><TD CLASS="quote">I agree we are installing one now and personally i think it takes more work installing a pre bent. you basically have to hold ever peice in the car to make sure the main hoop is in the right place so you have enough room to notch the other peices such as the piller bars and rear tree down tubes.
I also think it personally fits like ****, the notches are burned out and not to close to fitting the way i would like. definatly easier and much nicer to just fab on up custom.</TD></TR></TABLE>
Exactly right, we're actually going to redo the one i just finished, it fits that bad...
Old Oct 14, 2005 | 06:05 AM
fracas's Avatar
anyone else have any pix? I would like to see the bars welded to the plates please!!!
Old Oct 14, 2005 | 04:26 PM
Billy T.'s Avatar
The cage Tony speaks of is in my car. The rear half of the cage, including the door bars is alright(pretty damn good thanks to Tony), but the halo and the a-pillars bars are junk. You should be okay with the 8 point, but if you wanna do a full cage, at the very least, the a-pillar bars need to be custom.
Old Oct 15, 2005 | 04:44 AM
thermal's Avatar
Here:
https://honda-tech.com/zerothread?id=1268061
Old Oct 16, 2005 | 01:06 PM
fracas's Avatar
/\ Nice link.
La Maestra
Welding / Fabrication
17
Mar 8, 2013 04:55 PM
turtleEK1
Jul 4, 2012 01:52 AM
dxlol
Northern California (Sales)
Jun 2, 2011 10:17 AM
chairwitharmrests
Suspension & Brakes
14
Sep 25, 2007 09:14 AM
mugenek007
Sep 24, 2003 03:04 PM
