Which wire to splice for fuel pump kill switch??
Old Mar 4, 2002 | 07:46 PM
VXpride's Avatar
Default Which wire to splice for fuel pump kill switch??
Ok, I gave up on trying to remove the rear seats of my 92 VX because the freakin manual says see chapter 11 and it's not even in there. So I just found the wires that go to it, and I was wondering which wire i need to splice to hook up a kill switch. Also, I want to know how to take the back seat out if anyone knows... thanks
[Modified by VXpride, 4:53 AM 3/5/2002]
Old Mar 4, 2002 | 07:52 PM
SpeedracerS4's Avatar
Default Re: Which wire to splice for fuel pump kill switch?? (VXpride)
Ok this is for the 99-00 civic but I think they're the same with 92 - 95, the relay for the fuelpump its next to the glove box, take the glovebox off and its to the right. The wire that you need to splice is yellow/green, becarefull there's 2 yellow/green wires, its the thickest one. Hope this help~!
Old Mar 4, 2002 | 09:15 PM
TurboBumblBee's Avatar
as for taking out the seats on a 92-95 civic hatch, fold the rear part of the seat down, there is 1 tab on each side of the seat towards the armrest thingy, pull that off w/ some pliers, move the seats over a bit and pull out from the middle and outside, there is 1 10mm bolt holding the bottom part of the seat down at the rear of the seat, remove that and pull up on the seats and do the opposite to put everything back out..
Old Mar 4, 2002 | 09:18 PM
as for the fuel pump, ive never done this but if you put a switch on any power wire and turn the switch off when you get out of the car, it will cut power off so that it will not turn back on when you get back into the car agian w/ out turning it back on.. the relay might be a good place to do it but there is other places im sure as well.. i dont know where the relay is..
MrXclusivE
Apr 5, 2008 03:55 PM
Dropped90Integra
Audio / Security / Video
Feb 14, 2005 07:22 AM
ORcivicsi
Apr 2, 2004 01:03 PM
dLo GSR-stolen-now-WRX
Mar 24, 2004 04:41 PM
JLange
Jan 2, 2003 01:24 PM
