What's the best looking beads fluxcore can do?
Old Oct 10, 2005 | 11:18 AM
goingtobefast's Avatar
Default What's the best looking beads fluxcore can do?
Got my self a crappy fluxcore welder, wondering what's the best looking beads fluxcore can do. post somepictures
Old Oct 10, 2005 | 11:52 AM
Flashmn's Avatar
Default Re: What's the best looking beads fluxcore can do? (goingtobefast)
Did that a while back, flux core
Old Oct 10, 2005 | 12:03 PM
Dee's Avatar
Dee
Default Re: What's the best looking beads fluxcore can do? (Flashmn)
Flux core can do much better welds than that. I'll try to snap some pics while I'm at the shop tomorrow.
Old Oct 10, 2005 | 07:50 PM
LShatchie's Avatar
Default Re: What's the best looking beads fluxcore can do? (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">Flux core can do much better welds than that. I'll try to snap some pics while I'm at the shop tomorrow.</TD></TR></TABLE>
i gotta see this
Old Oct 10, 2005 | 08:27 PM
m R g S r's Avatar
wow...show me...cuz i REALLY suck then!!
Old Oct 10, 2005 | 08:53 PM
AspectIndustries's Avatar
Default Re: What's the best looking beads fluxcore can do? (m R g S r)
Yea, I'll post some pics for you guys later on too. It can do wayy better then that. U suck.
Old Oct 11, 2005 | 05:02 AM
LShatchie's Avatar
Default Re: What's the best looking beads fluxcore can do? (synik)
i just hate how my fluxcore welder wont feed the wire constant so i cant get a constant bead and it turns to a bunch of crap
Old Oct 11, 2005 | 05:29 PM
jaydmcrx's Avatar
Default Re: What's the best looking beads fluxcore can do? (LShatchie)
Flux core is a deep penetrating, soupy weld that gets extremely hot. Unless your using a homebase gasless welder with like no power going to it. Many people in industry use it for its great manipulating ability, and very fast feed speeds. Anywhere from 300 to 475 ipm. Thos things look like you could use some work. Flux core welds usually show little or no beed structure either.
Here is an example:
There is flux inside of the of the wire that protects the weld like an arc weld would do. It's pretty awsome actually. I don't see why you were calling it crappy?
Old Oct 11, 2005 | 06:59 PM
jaydmcrx's Avatar
If you machine is welding crappy, check the polarity on the machine. The cheaper ones have two wing nuts for the ground and power. Show's the instructions usually on the flip up lid.
Old Oct 12, 2005 | 08:54 AM
beepy's Avatar
Default Re: (jaydmcrx)
My welds using flux core were always deeper-penetrating for the same power consumption than gas shielded. I still use flux-core when welding mild steel.
Old Oct 12, 2005 | 06:34 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">i just hate how my fluxcore welder wont feed the wire constant so i cant get a constant bead and it turns to a bunch of crap </TD></TR></TABLE>
clean the feed wheels, check your power supply, turn down the power
I was having that problem, and atributed it to dirty feed wheels and an inconsistant power supply at high currents. It was dropping voltage to the feed motor.
Old Oct 13, 2005 | 12:57 AM
WhiteSol's Avatar
Default Re: What's the best looking beads fluxcore can do? (krustindumm)
Some of my self-shielding fluxcore welding looks better than my gas shielded mig. Bevelled edges, clean materials, correct wire speed are essential for a good FCAW weld.
I highly recommend you try lincoln NR211-MP (E71T-11) mig wire, it is suitable for up to 1/2" plate its a good wire to start out on.
Not one of my best current fluxcore welds, but it gives you the idea that you can make it pretty smooth weld. I'm definetly still learning also
Old Oct 13, 2005 | 01:21 AM
essex's Avatar
Default Re: What's the best looking beads fluxcore can do? (WhiteSol)
Some flux talk here:
https://honda-tech.com/zerothread?id=956688
Old Oct 14, 2005 | 01:16 AM
2old_honda's Avatar
Default Re: What's the best looking beads fluxcore can do? (essex)
i have a machine that will do both flux and gas. what if I turned on the gas while using flux wire? what effect will i get?
Old Oct 14, 2005 | 08:20 AM
beepy's Avatar
Default Re: What's the best looking beads fluxcore can do? (2old_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2old_honda &raquo;</TD></TR><TR><TD CLASS="quote">i have a machine that will do both flux and gas. what if I turned on the gas while using flux wire? what effect will i get?</TD></TR></TABLE>
Deep penetration and no spatter.
Old Oct 14, 2005 | 08:41 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default Re: What's the best looking beads fluxcore can do? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">
Deep penetration and no spatter. </TD></TR></TABLE>
just the way she likes it
LykewoaDC4
Apr 25, 2007 10:42 AM
YoungKadafi
Mar 22, 2007 02:27 PM
egCoupe
Oct 8, 2006 11:34 AM
surfrider
Jun 2, 2005 03:24 PM
hondaracing1on12004
10
Nov 17, 2004 11:35 AM
