FS: B18 Block, ITR oil pump, turbo timer, more...
Please pm for additional pictures or to make an offer on this stuff. Prices are negotiable.
Bump it if you look... thanks!
B18B Block, bored for 81.25 but bores are slightly tapered. This will work GREAT for someone needing a looser clearance...forged pistons, resleeving or someone with 81.5MM pistons, the block is PERFECT, clean. make an offer.
Also available is a perfect condition B18B Crankshaft... asking 65$
B16 Pistons & Rods - 1 bad rod as is visible... spun bearing, the rest is in good condition.... $30
B16 Crank Pulley... make offer
2 Brand new ITR P73 Pistons, STD size... 45$ each or 85$ for both.
H22 Intake Manifold, endyn ported... $100
ITR Oil Pump... $75 & LS Waterpump... $50 - both in good condition.
Greddy Turbo Timer, no harness... $60
Stock LS Clutch, came off working great, low mileage. make offer
H22 Flywheel, good condition needs resurface... make offer.
Also have an F22 Distributor internal coil...
If you want any more detailed pictures of any of these parts please let me know... i will get them to you. Also open to trades... let me know.
Bump if you're looking...
Modified by 93preludes at 9:37 AM 10/10/2005
integranator
Sep 10, 2007 06:37 PM
93preludes
Dec 14, 2005 12:26 PM
