how much does spring rate effect ride height?
I've been thinking of replacing the factory springs on my D2 coilovers with something a bit softer....
The factory rates being 9K/7K....now, if I were to switch to say 7K/5K, would there be a significant difference in how the car sits? Or is it negligible?
TIA!
TIA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">change in spring rate to static ride height is moot because you just adjust the height of your coilovers.</TD></TR></TABLE>
Thats what I thought
But just out of curiousity, if I was NOT running coilovers, would a change in spring rate like I've described (between 9k/7k and 7k/5k) affect ride height in any significant way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxmadman »</TD></TR><TR><TD CLASS="quote">
But just out of curiousity, if I was NOT running coilovers, would a change in spring rate like I've described (between 9k/7k and 7k/5k) affect ride height in any significant way? </TD></TR></TABLE>
it depends on the weight of the car and what you consider "significant". But yes, springs that are the same free length, but different rates will sit at a different height. The rate of a spring indicates the amount of weight it takes to compress the spring 1", so a 500lb spring will compress 1" when you put 500lbs on it. 2" when you put 1000 lbs on it, etc. So if you're running a spring that will compress 1" with your car's weight on it and you go to a higher rate, it's not going to compress 1" anymore.
You pretty much need to know your corner weights to know exactly how much it will change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">it depends on the weight of the car and what you consider "significant". But yes, springs that are the same free length, but different rates will sit at a different height. The rate of a spring indicates the amount of weight it takes to compress the spring 1", so a 500lb spring will compress 1" when you put 500lbs on it. 2" when you put 1000 lbs on it, etc. So if you're running a spring that will compress 1" with your car's weight on it and you go to a higher rate, it's not going to compress 1" anymore.
You pretty much need to know your corner weights to know exactly how much it will change. </TD></TR></TABLE>
excellent, thnx!
any idea how the different spring rates as I've described can affect the height on a CRX? (2nd gen)
excellent, thnx!
well, i was trying to say the question is moot (pointless) because you wouldnt be able to USE different spring rate type of springs without the coilover sleeve/collar which adjusts height.
but yes, having a different spring rate will adjust your static ride hieght ALL things equal, because its carrying the same amount of weight, at a different spring rate (weight/inch).
jetpilot
Suspension & Brakes
13
Oct 24, 2006 08:48 PM
91SiKen
Mar 5, 2002 06:34 PM
