1995 civic overheating!!!!
Old Oct 9, 2005 | 09:31 PM
mkink's Avatar
Default 1995 civic overheating!!!!
I have a 1995 Honda Civic DX. In the last 6 months, my car has been overheating. I have had replaced: radiator, both fans, thermostat, 2 sensors. However, my car keeps heating up to about 3/4. I have had to different mechanics check the Head Gasket, and they both said the gasket checked out fine. The only thing I notice is that antifreeze is leaking from the top of the overflow reservoir. It does this only when the car overheats. What is going on???? Thanks
Matthew
Old Oct 9, 2005 | 09:33 PM
perlmeister8's Avatar
Default Re: 1995 civic overheating!!!! (mkink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkink &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1995 Honda Civic DX. In the last 6 months, my car has been overheating. I have had replaced: radiator, both fans, thermostat, 2 sensors. However, my car keeps heating up to about 3/4. I have had to different mechanics check the Head Gasket, and they both said the gasket checked out fine. The only thing I notice is that antifreeze is leaking from the top of the overflow reservoir. It does this only when the car overheats. What is going on???? Thanks
Matthew</TD></TR></TABLE>
Water pump perhaps?
Old Oct 9, 2005 | 09:34 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeistere81 &raquo;</TD></TR><TR><TD CLASS="quote">
Water pump perhaps? </TD></TR></TABLE>
My guess.
Old Oct 9, 2005 | 09:36 PM
underb00steg6's Avatar
water pump is only thing you havent changed out ..just give that a try
Old Oct 9, 2005 | 09:50 PM
RangerDan's Avatar
Default Re: 1995 civic overheating!!!! (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">water pump is only thing you havent changed out ..just give that a try </TD></TR></TABLE>
Check the gauge also.
Old Oct 10, 2005 | 08:34 AM
egyolk's Avatar
Default Re: 1995 civic overheating!!!! (RangerDan)
Water pump, its the only thing that hasn't been checked must be it
Old Oct 10, 2005 | 09:32 AM
mkink's Avatar
Sorry, should have also mentioned:
new water pump and radiator cap. These were installed prior to the new radiatior.
Matthew
Old Oct 10, 2005 | 09:47 AM
Luserkid's Avatar
What exactly do you mean "leaking from the top of the over flow"? Is the overflow full?
Old Oct 10, 2005 | 12:24 PM
mkink's Avatar
Default Re: 1995 civic overheating!!!! (Luserkid)
When I open the hood, the top of the overflow container has antifreeze on it. Also, there is antifreeze on the top left side of the radiator and on the left side of the car, next to the overflow container. It looks as if someone poured anitifreeze on top of the overflow reservoir and it leaked off the sides.
Matthew
taylor67
Mar 23, 2017 01:23 PM
tjcletzgo
17
Nov 10, 2011 03:51 PM
panchlow
Dec 18, 2010 11:43 AM
dohclsv
13
Mar 12, 2008 06:10 PM
93eh2hatch
27
Dec 19, 2007 03:02 AM
