is any of this not nescessary???? please respond ASAP
well I am ordering all of this in a week or two so here it goes....tell me if any of this is not needed
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
portflow outer springs
type r inners
ported and polished head
3 angle valve job
hondata
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
Also I think you want to get portflow inners(he doesnt have outers) and ITR outers (not inners)
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
pistons? cam gears? headgasket/IM gasket?
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
Pinhead: Power Enterprise TBelt I hope?
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
Another Fire extinguisher for the driver side A-pillar
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
D
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
definatly no need for fire supression.....
D
Eagle Rods
new bearings
new water pump
new timing belt
new head bolts
jun3 cams
portflow retainers
type r inners
3 angle valve job
hondata
D
I would keep stock head gasket, just do a 3 layer, your compression will be high enough IMHO.
other than that looks good.
but see how my Toda B's do before purchasing the cams
type r inners
Toda Valve Springs
They will handle more lift.
type r inners
Toda Valve Springs
Why the stock head bolts and not ARP hardware?
Jason
Stock headbolts are good enough; or spend the extra $120 for the arp studs. He should spend that on the valve springs; Why not JUN valvesprings since you are using JUN cams?
[Modified by t, 11:16 PM 3/4/2002]
look into the skunk cams there 2's are comparable to the jun 3's and depending on your setup there 3's are monsters with 12.8mm lift on the intake as compared to 12.3 with the juns +\- .1 i forgot exactly. definetely need better valve springs and the machinist should be aware of which cams your runing as well!
Yea i figured I'd go with something that's been around for a while and has been tested many upon many times.....what about getting skunk2 valvesprings and retainers...any good???
HONDADATA?
boyyyyyyyyyy need to go get your self some motech!
And find sumone to tune that shi)t for you. Or D.F.I
MOTECH!!!!!!! (spelling)!!!
[Modified by RPM_CRAZY, 9:56 AM 3/5/2002]
MOTECH!!!!!!! (spelling)!!![Modified by RPM_CRAZY, 9:56 AM 3/5/2002]
looks good bro, few typos but what the hell, you'll like the setup when you are done, very similar to mike m's old setup in the hatch, he hit 198whp i believe and about 130 or so torque
have fun with it, but remember dyno tune it and you are going to need about 2hrs+ on the dyno with mike k to get the hondata down and the cams adjusted so figure in an extra 400.00 right there
