itr cams in my gsr
Old Oct 9, 2005 | 07:49 PM
GSRintegra_Bob's Avatar
Default itr cams in my gsr
will itr cams make a bigger difference then my gsr cams? or will i just be better off buying aftermarket cams?
Old Oct 9, 2005 | 07:50 PM
Sack Master's Avatar
Default Re: itr cams in my gsr (GSRintegra_Bob)
You would probably be better off getting after market cams but ITR cams will make a pretty good increase in power.
Old Oct 9, 2005 | 07:52 PM
M0NEYnH0s's Avatar
lightly modified and tuned it will make a significant difference. If youre looking for serious NA power keep in mind you would have to purchase more than just aggressive aftermarket cams.
Search. There are plenty of dynos to prove the potential of ITR cams.
Old Oct 9, 2005 | 08:28 PM
Spectrum24x's Avatar
Default Re: itr cams in my gsr (M0NEYnH0s)
ITR Cams will help, but there ITR, there gonna be overpriced, for what you pay you can get a good set of aftermarket cams, but then you gotta get springs and retainers.
good luck!
Old Oct 9, 2005 | 11:24 PM
kevpotts's Avatar
Default Re: itr cams in my gsr (Spectrum24x)
itr cams wont necessitate new retainers though... because gsr and itr retainers are the same.
Old Oct 9, 2005 | 11:50 PM
redlineintegra's Avatar
Default Re: itr cams in my gsr (kevpotts)
Just buy the ITR (00/01) intake cam, exhaust cams are exactly the same.
Old Oct 10, 2005 | 12:11 AM
2G0S0R1's Avatar
New User
Default Re: itr cams in my gsr (redlineintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineintegra &raquo;</TD></TR><TR><TD CLASS="quote">Just buy the ITR (00/01) intake cam, exhaust cams are exactly the same.</TD></TR></TABLE>
Please take back your comment so I dont have to prove you wrong(if you meant gsr-vs-itr exhaust cams are the same???)... thanks
ITR cams are cheaper than most aftermarket sets and help a good bit, but keep in mind thet they are still OEM and not made strictly for power.
You need the ITR valvesprings (intake side, then use GSR intakes on your exhaust side) to get all the potential they offer (higher peak HP).
Retainers are the same.
I like them.
Old Oct 10, 2005 | 12:28 AM
1turbodc2's Avatar
i would do aftermarket cams, u will get more gain, there was a write up on skunk2 stage 1 cams vs. ITR cams, and the Skunk2 cams, had a signifigant amount of power gains over the ITR cams....
Old Oct 10, 2005 | 05:38 AM
thanks alot everyone... i was stuck between itr cams... or i was just going to grab my ***** and buy some toda b's... but then i have to do timing belt and springs and retainers... ahhhh i hate money
Old Oct 10, 2005 | 09:33 AM
Default Re: (GSRintegra_Bob)
Skunk2 Stage 1's don't require valvetrain upgrade...
it's recommended, but you can get away without.
Old Oct 10, 2005 | 09:47 AM
kevpotts's Avatar
Default Re: (Spectrum24x)
i dont understand that though, if the itr cams "require" upgraded valvesprings... and the skunk2's are more aggressive than the itr's, wouldnt that necessitate new valve springs? now i understand that you can run itrs on stock gsr springs, but i wouldnt just becasue honda didnt. so maybe im just a stick in the mud
Old Oct 10, 2005 | 09:49 AM
CNSK's Avatar
I would go itr intake cams with aftermarket sprokets w/ hondata and dyno tune it....you'll see some gains....
A13sechatch
Mid-Atlantic (Sales)
Nov 19, 2008 04:51 AM
Jbur074
Mar 16, 2008 03:08 PM
Easyslider01
Oct 7, 2006 04:23 PM
Rhetoric
Sep 10, 2001 07:52 AM
