Where's my turn signal fuse ('95 EX)?
I checked under the dash and under the hood, the diagram saying what each fuse is for has none that sounds like it's for the turn signal. Searching the board showed nothing, neither did Google, a little help?
its a 10 amp fuse under ur hood. when u take the cover off lookin straight at it from in front of the car its the one closet to the bottom right corner.
You're positive it's the same as the Hazards? In short, while installing sidemarkers, i shorted both sides due to them being self grounding. I turned on the left, it worked for awhile, started blinking really fast, then stopped working, same for the other side, then i tried the Hazards, same thing, replaced the Hazard fuse after fixing the wiring, hazards work fine, no turn signals at all.
For all the posts this goes unanswered in.
The turn signal fuse is named "Back-up light", it is located on in the cabin, 10A fuse to the Right of a 20A and nothing else beside it to the Right, i believe it was in the back row on the left side.
Mishima
Jun 30, 2009 09:08 PM
