Gauge cluster and fuel pump dont work after engine swap
Old Oct 9, 2005 | 04:16 PM
Muckman's Avatar
Moderator in Chief
Default Gauge cluster and fuel pump dont work after engine swap
I have been helping a friend swap a D16A6 from a 91 Civic Si into an 89 CRX DX. This swap included a conversion from the CRX Dual Point Fuel Injection to MPFI with the Si motor and also automatic to manual.
We swapped over the Si motor, engine harness, dash harness, gauge cluster, interior and engine fuse boxes. Basically all the guts of the Si except for the rear harness are now in the CRX.
The problem is the tachometer, fuel gauge, temp gauge DO NOT WORK. As well as the fuel pump doesn't get power either. However the rear running lights work but not the brake lights, reverse lights, or turning lights.
<u>We hard wired the fuel pump with a switch and the car drives fine!</u> The cluster is getting power because all the lights on it work. CEL, Battery, seat belt lights etc. power up when key is turned on.
We've have tried swapping between the CRX AND Si cluster, as well as both dash harnesses in every conceivable combination! Both clusters power up, but gauges still do not work. All fuses are good, all grounds have been checked, and all clips are plugged in.
We need some serious help! Can I use the chassis harness in the CRX now or do I need to swap the Si chassis harness?
Old Oct 10, 2005 | 10:02 AM
Muckman's Avatar
Moderator in Chief
Default Re: Gauge cluster and fuel pump dont work after engine swap (Muckman)
If you swap an engine, the engine harness, the dash harness, the engine fuse box, the cabin fuse box, the gauge cluster AND the ECU, there should be no reason why these things dont work. Especially when everything plug in without any issues. Everything that's anything important has been swapped over. What are we missing here?
Does anybody have any ideas?
Old Oct 10, 2005 | 10:03 AM
k91's Avatar
k91
Main relay working?
Old Oct 10, 2005 | 10:20 AM
bch5428's Avatar
Default Re: Gauge cluster and fuel pump dont work after engine swap (k91)
yes tested and functional. tired the set up with both the DX and Si relays, seems to be no difference.
Old Oct 10, 2005 | 10:58 AM
vtecn8ive's Avatar
Default Re: Gauge cluster and fuel pump dont work after engine swap (bch5428)
check your grounds. When dealing with switching out this much of the wiring its a common error.
Old Oct 10, 2005 | 01:22 PM
Muckman's Avatar
Moderator in Chief
Default Re: Gauge cluster and fuel pump dont work after engine swap (vtecn8ive)
We got it figured out. A clip was plugged into the wrong connector.
Modified by Muckman at 12:42 PM 10/12/2005
baphomet
11
Nov 7, 2020 06:03 PM
sho_shane
Feb 22, 2014 06:34 AM
baphomet
May 3, 2006 10:13 AM
Muckman
Oct 12, 2005 08:15 PM
veganej
Aug 26, 2004 06:52 PM
