obd-0 b16 in to obd1 teg
my friend has a b16 that came out of his ef and i am going to get it so can you all help me out what would i need to swap
Modified by 89 pos at 5:24 PM 10/9/2005
You will need to relocate the plug for the coolant temp sensor. OBD-0 is on back of the block under the oil filter, and obd1 is on the thermostat housing. You will need to get OBD1 Injectors, ECU, and Distributor. Other than that, they are the same. Hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDB2 »</TD></TR><TR><TD CLASS="quote">You will need to relocate the plug for the coolant temp sensor. OBD-0 is on back of the block under the oil filter, and obd1 is on the thermostat housing. You will need to get OBD1 Injectors, ECU, and Distributor. Other than that, they are the same. Hope that helps</TD></TR></TABLE>
werd. the temp sensor screwed me up for a while...haha.
u'll also have to hook up vtec. you can find pinouts at ff-squad.com.
isn't an 89 teg obdo?
anyways...
u can use the injectors (obd1/92teg), dizzy (obd1/92 teg), and an obd1 vtec ecu. u'll need to get the plugs that connect to the vtec solenoid.
anyways...
crazyef8
10
Apr 20, 2009 09:44 PM
E36 Guy
Aug 2, 2006 12:20 AM
itsJDMyo
Feb 4, 2005 06:18 AM
