EMERGENCY!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">manuel trans? if so look by where the passenger side axle goes into the tranny and theres a big 17mm bolt you cant miss. its gonna be towards the back of the tranny.</TD></TR></TABLE>
i gotta fill it there?
..tranny oil/fluid usually works for transmissions.....
but yea i know its kinda wierd but that 17mm is where u fill the tranny fluid...use a small tube and have it come up and then use a funnel..if your fill bolt is stripped/rounded which is VERY common, you can just pull the pasenger side axle out and fill through there...
i think 1.9quarts or so, or as they "till the fluid pours out the fill hole"..
It's easy. Using a 3/8" ratchet, plug it into the tranny drain hole on the bottom of the tranny. Put a bucket or something under the hole to catch the old fluid. Undo the bolt and let it drain. While it's coming out, use a 17mm wrench to take off the filler bolt (it'll be located just between the transmission and the mounting point for the passenger-side lower arm, where it mounts to the body). Remove that bolt, and save the washer. Then get a long-neck filler tube and feed it into the hole. When the tranny's done draining, put the bottom bolt back in and start filling up the transmission. When fluid begins to weep from the upper hole, that's it you're done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d »</TD></TR><TR><TD CLASS="quote">..tranny oil/fluid usually works for transmissions.....
local mechanic says motor oil for trannny.
</TD></TR></TABLE>local mechanic says motor oil for trannny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyris »</TD></TR><TR><TD CLASS="quote">
Honda MTF, Pennzoil/GM Synchromesh (especially if you have grinds or notchy shifting), or at last resort you can use 10w30 motor oil if you can't find anything else.
</TD></TR></TABLE>Honda MTF, Pennzoil/GM Synchromesh (especially if you have grinds or notchy shifting), or at last resort you can use 10w30 motor oil if you can't find anything else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyris »</TD></TR><TR><TD CLASS="quote">is this bolt left-hand thread?!?!?!?!
it wont come off
You might need a cheater pipe / breaker bar.
it wont come off
</TD></TR></TABLE>You might need a cheater pipe / breaker bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">
Honda MTF, Pennzoil/GM Synchromesh (especially if you have grinds or notchy shifting), or at last resort you can use 10w30 motor oil if you can't find anything else.</TD></TR></TABLE>
thats what i use
thats what i use
it wont come off </TD></TR></TABLE> Breaker bar is your best freind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 »</TD></TR><TR><TD CLASS="quote">^ Or hit the ratchet with a hammer.</TD></TR></TABLE>
be careful though use a 6-point socket/wrench....cuz that bolt strips easy..
be careful though use a 6-point socket/wrench....cuz that bolt strips easy..</TD></TR></TABLE>
i noticed
thank you all for your help (i know this response is a tadd late i.e 38 hours
we got it off in about 40 min and only wrecked 1 tool
. despite our best efforts to use propor tools and not strip the bolt, the 6-point wouldn't even fit the bolt when it came time to put it back on
but now she has all her fuids and shifts a little smoother. we even put on her winter shoes
(the fronts were slicks and the back was getting there)
i noticed
)we got it off in about 40 min and only wrecked 1 tool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyris »</TD></TR><TR><TD CLASS="quote">i need a pic of whare you fill the transmission fluid on a stock 90 civic sedan d engine.
Uncle accidentally drained transmission!!!
How do you accidently drain the transmission????????????
</TD></TR></TABLE>How do you accidently drain the transmission????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyris »</TD></TR><TR><TD CLASS="quote">Uncle accidentally drained transmission!!! </TD></TR></TABLE>
Everyone's uncle is incompetent. Just think of everyone you know, and how much stuff their uncle screws up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">
wizzards581
Apr 5, 2002 10:20 AM
