h22 in a 91 integra
Old Oct 9, 2005 | 12:16 PM
iluvef8's Avatar
Default h22 in a 91 integra
i have a 91 intregra and i want to drop an h22. how hard is that because i know they come hydrolic and linkage is different. i've herd that you have to do something to the firewall
Old Oct 9, 2005 | 12:36 PM
95lstegman's Avatar
Default Re: h22 in a 91 integra (iluvef8)
first off, understand that your engine bay is JUST big enough for that engine. second, the H22 has a cable-activated shifter, not rod-activated. third, your engine mounts, axles, and vehicle/ECU wiring will be inadequate. you'll need some wiring help, new mounts, new axles, H22 shifter cables, H22 shifter assembly (the WHOLE thing), and even then that front subframe thing on the DA may or may not clear properly. just because the H22 swap is a bit cheaper than a GSR swap doesn't mean it won't cost more by the time you're done. but WILL have so much torque you won't know what to do with it any more .
Old Oct 9, 2005 | 12:38 PM
h4x's Avatar
h4x
Search, this topic has been covered a million times.
Have fun steering!
Old Oct 9, 2005 | 01:02 PM
95lstegman's Avatar
Default Re: (h4x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4x &raquo;</TD></TR><TR><TD CLASS="quote">Search, this topic has been covered a million times.
Have fun steering!</TD></TR></TABLE>
seriously, you act as if the H22 is a lot heavier than a b18.
Old Oct 15, 2005 | 08:10 PM
IOSUA's Avatar
h22 is only 60lbs. more than the b18. not that much different. h22's in integras r nice.
Old Oct 16, 2005 | 02:41 AM
gsrvtec2's Avatar
Default Re: (jdm dc2 01)
have fun going through drama and spending more $$$ with the h22
bobo-jenkins
Mar 7, 2012 03:45 PM
Pure Sol
Dec 20, 2004 08:49 PM
301am
Nov 4, 2004 11:57 PM
kev tec96
Jun 19, 2003 10:46 AM
junglerunna
Dec 2, 2002 10:03 AM
