can i use a stock b16 intake manifold for the blox manifold i'm about to buy off ebay
i'm about to buy a blox manifold and i need the intake gasket can i just use a stock b16 intake manifold gasket or do i have to get one for the blox manifold if so where can i get it from
you can buy one from the dealer # 17105-P73-AO1, if you have a 1st gen b16 you will also need a 99 si fuel rail and fuel hose(the one that goes from the rail to the fuel filter) as on the blox manifold the intake temp sensor is on a different runner and will hit the FPR unless you get a newer style fuel rail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">you can buy one from the dealer # 17105-P73-AO1, if you have a 1st gen b16 you will also need a 99 si fuel rail and fuel hose(the one that goes from the rail to the fuel filter) as on the blox manifold the intake temp sensor is on a different runner and will hit the FPR unless you get a newer style fuel rail</TD></TR></TABLE>
or you can relocate the IAT
i can't use my stock jdm fuel rail because being that it a obd0 jdm b16 motor i was told that when i need part i can get it from a 94 honda del-sol or a 99 civic si and your saying that i have to use a 99 civic fuel rail and the gas line so i should be good and for the sensor how is that working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">i can't use my stock jdm fuel rail because being that it a obd0 jdm b16 motor i was told that when i need part i can get it from a 94 honda del-sol or a 99 civic si and your saying that i have to use a 99 civic fuel rail and the gas line so i should be good and for the sensor how is that working</TD></TR></TABLE>
From my understanding, the reason you need the new fuel rail is because the fpr on the obd cars hits the intake air sensor. You might also have to t off some coolant lines, I just installed this manifold on a gsr and I had to t some lines off. But thats a totally different engine, just something you might want to be on the look out for.
LS1Bait
Jan 15, 2009 07:04 AM
